yes some tomatoes were "killed" in the process
without proper mills, flat bed cutting tools, etc ... making this is quite a challenge
the rail length is 750mm, total movement accessible is approx 660mm.
calculated per step movement is roughly 5microns ++. but with wood flexing and play, i wouldnt know until i get my hands on a dial (which is coming in next month i think, even so i think wood flex might just easily account for 1 step length).
the flange bearings are type F688z. 2 units inverted gives a nice "ride" for the belts which are XL 9mm.
3roomlabs.blogspot.sg]
______________________________________
__my mixed bag blog || aka --> [
http] || ___ so 3D printing is everywhere ... dont worry, hospitals can now 3Dprint body parts, they will charge you $1million excluding surgical fees ... you will die paying your debts. thats their aim ___ if every patent expires tomorrow, everybody will surely get a 3dprinter and make EVERYTHING ! ____ there is a "DIY-DTG" t shirt printing forum, you can mod an EPSON printer to PRINT like a pro. ___ CNCzone? overly commercialized it seems ___ my country? they will be taxing you for every cm of road you use and track you to your grave using GPS and its government authorized, now they will fire all the traffic wardens instead.___ EEVBLOG? there is only 1 way to do things --> take it apart like a pro
