Dreaming of a Static Motor Arrangement and Less Vitamins April 25, 2013 03:33PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 25, 2013 07:15PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 25, 2013 09:46PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 26, 2013 12:32AM |
Admin Registered: 13 years ago Posts: 730 |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 26, 2013 09:07AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 26, 2013 09:45AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 26, 2013 10:09AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 26, 2013 10:49AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 26, 2013 12:57PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 28, 2013 05:09PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 29, 2013 04:49AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 29, 2013 04:51AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 29, 2013 10:58AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins April 30, 2013 02:19PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 01, 2013 10:18PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 02, 2013 11:20AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 03, 2013 07:16PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 04, 2013 05:03AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 04, 2013 08:00AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 05, 2013 12:35PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 05, 2013 06:40PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 05, 2013 10:15PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 06, 2013 12:54AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 06, 2013 12:39PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 08, 2013 01:56AM |
Gene Hacker
Now on the issue of tape: converting these files for reprap wallace [www.thingiverse.com] to gcode using Slic3r, I get a gcode file that is 315 kb in size. Assuming we can convert file size directly to tape and standard 7 bit tape with a hole spacing of 0.1 inches. We get a tape ((315 kilobytes) / (7 bits)) * 0.1 inches = 0.9363456 kilometers long. Using this online calculator here [www.handymath.com] to figure out roll diameter, and assuming an inner diameter of 1.5"(toilet paper tube), we get a roll diameter of ~ 70 centimeters(~2.25 feet). So I guess this would be reasonable in terms of storage.
N7 G1 X2.0 Y2.0 F3000.0*85takes up 208 bits (26 bytes) in a plain text file (or more if you count end-of-line characters), but using Will's scheme it could be stored in 24 bits (3 bytes). You won't get error correction, and the resolution and maximum travel distance will be limited, but we can live with those limitations.
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 08, 2013 07:06AM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 08, 2013 10:21AM |
Abstract
The scale of environmental impacts associated with the manufacture of microchips is characterized through analysis of material and energy inputs into processes in the production chain. The total weight of secondary fossil fuel and chemical inputs to produce and use a single 2-gram 32MB DRAM chip are estimated at 1600 g and 72 g, respectively. Use of water and elemental gases (mainly N2) in the fabrication stage are 32000 and 700 g per chip, respectively. The production chain yielding silicon wafers from quartz uses 160 times the energy required for typical silicon, indicating that purification to semiconductor grade materials is energy intensive. Due to its extremely low-entropy, organized structure, the materials intensity of a microchip is orders of magnitude higher than that of “traditional” goods. Future analysis of semiconductor and other low entropy high-tech goods needs to include the use of secondary materials, especially for purification.
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 08, 2013 03:26PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 08, 2013 04:22PM |
Re: Dreaming of a Static Motor Arrangement and Less Vitamins May 08, 2013 04:38PM |
