AC for PCB print bed
Posted by rick55
June 12, 2013 08:37AM
I have a PCB print bed from Romscraj, and it appears well made, but it heats very slowly. From about 20C ambient to 60C, it takes an hour. It has 12V at the board, but when I check resistance, it shows 6 ohm. So 12V is only generating 24W. No wonder it heats slowly.
I have a 24V transformer, which would give 96W. Not ideal, but a lot better. I was just going to do it, but then I considered that running AC into a bunch of traces might create a whole bunch of signal that wouldn't be a good idea. Does anyone out there use AC for a PCB print bed? Any observed problems? It isn't a big deal to rectify the AC and smooth it a bit, but I prefer simple, if it's possible.
Thanks;
Rick
VDX
Re: AC for PCB print bed
June 12, 2013 04:18PM
Hi Rick,
I'm heating my bed with 230VAC - but with a SSR, that is switched with the 12V-heatbed-MOSFET of the RAMPS at maybe 10mA winking smiley
Viktor
June 12, 2013 04:38PM
VDX Wrote:
> Hi Rick,
Thanks, Viktor: if you're doing it at 230V, then I should be able to do it at 24V without any problems.
Rick
June 13, 2013 04:30AM
June 13, 2013 06:53AM
50Hz won't create nearly as much electro magnetic noise as DC PWMed by fast MOSFETs with no slew rate control.
June 13, 2013 09:41AM
VDX Wrote:
> Hi Rick,
Viktor,
I am thinking of doing something similar but am confused as to the specs for the SSR that I need. DO you have the specs, or perhaps a manufacturer or source, for the SSR you are using. What I don't understand is that some of them say they switch AC and some of them say they switch DC. Drawing my my knowledge of a normal magnetic relay, I don't see why AC or DC would matter.
Thanks
VDX
June 13, 2013 10:02AM
... it's mostly for the type of primary switching semiconductor - for "DC-switching" it's a transistor or MOSFET type and will drive the current when the input voltage exceeds the threshold value (mostly +3V).
"AC-switching' is done with a thyristor - this device switches on when the input voltage changes from negative to positive and blocks when from positiove to negative ... so when activating with +5V it would drive the current, but for blocking you'll need a negative input voltage and then again a positive level for activating, what's really simple with an AC input, but limits the switching speed to the 'zero-passes' of the AC waveform ...
Viktor
June 13, 2013 10:36AM
> Thanks
Here's an overview from Omron, describing the variations.
June 13, 2013 10:41AM
> waveform ...
Ouch: I didn't consider this, also Nophead's comment about PWM without slew-rate control. I'll have to look at the firmware, see if I could make the on/off times longer while keeping the duty cycle.
June 13, 2013 04:32PM
Re: AC switching delay.
At least with the Marlin firmware I'm using (v1, Durbie branch), the bed isn't PWM'ed or PID'ed. The bed is checked on a 2-second interval, and turned on or off, as needed.
So the zero-cross SSR looks reasonable. For someone who wants something cheaper, a triac should work with this firmware.
NOTE: if you're using two switch-mode power supplies without isolation transformers, or one supply without transformer to drive a triac to control mains voltage, make sure you provide some kind of isolation between your electronics and the triac.
Edited 1 time(s). Last edit at 06/14/2013 08:05PM by rick55.
