PrusaNozzle Mod For Large Scale Printer
Posted by Iceman086
July 14, 2013 03:28PM
Hello,
I am working on a large scale machine (in excess of 1 meter cubed) that would use a nozzle with a larger diameter head to allow for thicker layers to decrease print time on large builds.
I am considering getting a Prusanozzle and boring out the tip to 1 mm diameter. I would like to get some feedback from others on if they feel this would work?
Also, I feel I may need a larger (longer) chamber with a second heater to allow for a larger volume of material to be used. I was wondering if anyone had any thoughts in this as well?
If it comes to it I have a design in mind that may work with two custom heater blocks. I would run it as though I am using dual extrusion. With a second head that is never used to help control the head within cura.
Thank you for your time and input!
Also here is a link to my blog.
Rocca Productions Blog
VDX
Re: PrusaNozzle Mod For Large Scale Printer
July 14, 2013 05:17PM
... attached are two images of my first tests with PLA and a 0.8mm-nozzle - it's flowing really easy, but retract and overhangs are a bit more tricky than with thinner bores ... with 1mm even more ...
Viktor
open | download - m08.jpg (45 KB)
open | download - m08-2.jpg (30.4 KB)
July 14, 2013 05:57PM
Iceman086: Simba did some tests with a 1mm nozzle and seemed pretty happy with the results. See this thread.
VDX: Is that a metal box in your picture? Or just really shiny PLA? winking smiley
VDX
July 15, 2013 06:43AM
... this was translucent/transparent PLA winking smiley
Viktor
