[POLOLU PINS]: Difference between SLEEP and ENABLE
Posted by aj.moreno
December 16, 2013 10:03AM
I am developing now a device which use pololu for driving a NEMA 17. The movement is equal to axis Z Prusa movement. As Arduino RAMPS, I want to control 3 parameters of the driver: STEP, DIR AND ON/OFF. I have read a lot about pololu (and stepstick), but it is not clear for me, what is the best option to control the status (ON/OFF) of Pololu, if to use SLEEP pin or ENABLE pin - really I have not found the difference between them. In my first prototype, I have used SLEEP, and then I have realized that Arduino and RAMPS use ENABLE.
What is the difference between ENABLE and SLEEP? What is the best option?
Thank you very much,
Antonio
Re: [POLOLU PINS]: Difference between SLEEP and ENABLE
December 16, 2013 02:35PM
The difference, as I see it, is the state in which the pin enables your Pololu. Choose the pin that is more convenient for you to drive. Both pins will disable the output FETs.
December 17, 2013 03:41AM
Thank you very much jkoljo.
then the next question is, what is the difference between SLEEP state and ENABLE state and how can I evaluate which is better for my device performance?
December 17, 2013 11:48AM
To control the chip, you can either:
- Tie enable pin to vcc, and pull sleep down to disable chip when you want
- Leave sleep alone, pull enable up to activate, and leave it alone to disable chip when you want
December 17, 2013 02:29PM
The main difference between SLEEP and ENABLE is that SLEEP disables the entire chip meaning the motors will return to a full step position when powered on again. ENABLE only disables the motors, but leaves all the other logic unaffected. Source: [staceyw1.wordpress.com]
