I am actually building my own gcode generator, and I do not understand one thing about speed units. When I use a standard gcode generator program, as Slic3r, you set the speed in mm/s; however, when you check the gcode, the feedrate is set in mm/min (the feedrate value is multiplied by 60). And what it was really surprising for me, Marlin code take the speed value and divide it by 60, coming back to mm/second.
Why is the feedrate converted from mm/sec to mm/min??
Thank you very much!!
Antonio
