That would be really useful Zach - I just put something together that works - it
ain't pretty and I ain't proud. I'm not sure about making it bigger, though -
remember that two of them need to be moved about by the cartesian system.
Indeed I had thought about making it smaller by replacing the breadboard area
with a single connector so people can tack on another small board if they want
to fool with it.
Yours
Adrian
staff.bath.ac.uk]
reprap.org]
Zach Hoeken wrote:
> Hey Guys,
> I finally bit the bullet and learned Kicad. Its really not too bad
> once you play around with it for a while. Anyway, I wrote up a list
> of things I'm going to try on the builders blog. If you'd like to
> look over it and make suggestions, that would be great.
> I'm thinking about making the board bigger. Its pretty small as-is
> and since we're doing this by hand that can cause problems. 5"x6"
> (127mm x 152mm) is the size of board i'm looking at... is there an
> equivalent 'standard' size board in metric? it just seems that there
> is wasted space on the board with the current design and theres no
> reason to make it that small if we dont have to.
> the board itself is just fine... i'm just trying to make it simpler /
> less error prone for people to make. this will be really important
> once we start getting an influx of people attempting to construct the
> board and also once we start trying to fabricate them with the machine
> itself.
> ~Zach
> _______________________________________________
> Developers mailing list
Developers@reprap.org
reprap.org]
reprap.org]
