Alternate auto bed leveling idea.
March 26, 2014 06:11PM
Hi All
I serched the forum but did not find this idea so let me know what you think of it.
im planning to create a new printer for myself so that i can print my didjeridoos in one go.
Since my printer will have 3 z spindels for the bed, (lower z, hotend on x&y) i had an idea for a simple auto bed leveling, without servos or probes.
The idea is quite simple:
Hook up each spindel to a own stepper driver. one left,right and the last on the back.
Then use 3 endstop and place them on the 2 front corners and one on the back. Calibrate the endstops.
Now the idea is that when one of the endstopps trigggers stop that spindel from turning, till all 3 endstops have triggerd and all spindels have stopped.
lower z and repeat till all 3 endstops trigger at the same time.
The bed is them perfectly plane to the endstops.
Cons: 3 controlled stepper drivers for Z (not caining them like with a megatronics)
will not work for the 2 spindel printers such as the prusa i3
pros: no extra hardware, no probes or servos. easy to understand smiling smiley
Since whenever i say that i print Didjeridoos a lot of questions start popping up i think a video says more than words, have a look at my latest one with 64 rgb leds. 3d Printed Dij
If youre an audio programmer from europe and would like to have one of my didjes or a Oversized Lamp smiling smiley (when my new printer is done), i need help with the fft from the mic! send me a pm.
Well thats it for now let me know what you think.
Edited 1 time(s). Last edit at 03/26/2014 06:13PM by technoshaman.
TechnoShaman Didjeridoos www.ts-dij.com
Re: Alternate auto bed leveling idea.
April 04, 2014 10:11AM
Interesting idea but there is a flaw:
Is the bed is level relative to the end stops - yes
Are the end stops level relative to the XY axes - not necessarily!
You could have quite an angle in either the X or y axis and this system would never show it since there is no link between the two. That's the whole advantage of bed probing, it levels everything!
Putting a probe on your print head and levelling using 3 Z rods - this could be perfect and I don't think it is any more difficult than the 3 end stop system.
