RepRap Interface Standard April 10, 2014 02:47PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: RepRap Interface Standard April 11, 2014 11:29PM |
Re: RepRap Interface Standard April 12, 2014 05:36AM |
Re: RepRap Interface Standard April 13, 2014 09:45AM |
Re: RepRap Interface Standard April 14, 2014 05:37AM |
JustAnotherOne
What if we just put the heater and temperature sensor into the electronics module?
JustAnotherOne
End Stops could then be like "sub modules" of the electronics module. A electronics module would be compatible with several kinds of end stops(micro switch, optical, magnetic,..). But the printer bode would only need to provide the place and the holes for the screws.
Re: RepRap Interface Standard April 14, 2014 11:31AM |
Re: RepRap Interface Standard April 14, 2014 04:12PM |
Re: RepRap Interface Standard April 14, 2014 05:42PM |
Re: RepRap Interface Standard April 15, 2014 03:57AM |
Re: RepRap Interface Standard April 15, 2014 04:49AM |
JustAnotherOne
If someone has a printer like this and buys a print head module that does not come with a heater device he will just use the heater he has with the old one.
Re: RepRap Interface Standard April 15, 2014 06:20AM |
samp20
@JustAnotherOne, I have a few arguments to put forward against your suggestion:
Re: RepRap Interface Standard April 15, 2014 09:45AM |
Re: RepRap Interface Standard April 16, 2014 04:51AM |
JustAnotherOne
The Idea with the heater is that all print heads use the same hole for mounting the heater. Are there any reasons for incompatible heater mounting solutions on the print head?
Re: RepRap Interface Standard April 16, 2014 08:18AM |
Re: RepRap Interface Standard April 16, 2014 05:12PM |
JustAnotherOne
I think it is good if a standard contains the reasons for its definitions. So it would be good to have them in the Wiki, too.
Re: RepRap Interface Standard April 17, 2014 08:46AM |
JustAnotherOne
I never heard of gluing in the heater. Is probably interesting to find the best glue for that.
JustAnotherOne
If the heater is part of the hot end then the standard must also define the min and max resistance of the heater.
Re: RepRap Interface Standard April 17, 2014 09:14AM |
Traumflug
JustAnotherOne
Electronics side defines a given voltage and maximum current and the heater should be able to deal with this envelope. I'm just a bit struggling wether definition of the electronics side can go into RIS 1 or wether it needs it's own RIS.
Now, endstops are defined in RIS 2 and it looks reasonable to refer to this definition in RIS 1. Could be the same for heaters. Or whole extruders?
