Power Supply for NEMA17 stepper motors
Posted by zerg
April 17, 2014 04:52PM
Hi All!
I have a Power supply (3-12V and 1A), is it enough for 2 NEMA17 stepper motors?
NEAM17 Parameters - 5V and 1A
i would use these motors for plotter
please help!
Edited 1 time(s). Last edit at 04/17/2014 06:28PM by zerg.
Re: Power Supply for NEMA17 stepper motors
April 18, 2014 03:30AM
yes you can use but at 0.25- 0.4 amps per motor.... a better supply would be 2 amps
April 19, 2014 08:35AM
Hi!
I would use these two motors to build a wall plotter, so in this situation (if i move a pencil and dammil), this power supply would be enough?
- Power supply (3-12V and 1A)
- NEAM17 Parameters - 5V and 1A
Someting like this :
And thank you for the perevious answer
Edited 1 time(s). Last edit at 04/19/2014 08:36AM by zerg.
April 19, 2014 12:52PM
Been there done that .. It will work for this.. I built the same thing using a 6v 1 amp supply using unipolar nema 17 motors.
April 19, 2014 02:24PM
it's sounds good, but there is a mistake in NEMA17 parameters, this is the correct:
NEMA17 Parameters: 5V and 1,2A
with this parameters is also good?
Edited 1 time(s). Last edit at 04/19/2014 02:27PM by zerg.
