4 axis printer for more overhang
June 18, 2014 05:32AM
Hi!
I made a fourth axis upgrade for my prusa mendel i2 and in a first test I was able to get 80 degrees of overhang. I am using a 0.9 mm nozzle, extruding 1mm wide and 0.75mm high layers.
In the first part of the test object I was tilting the nozzle to about 20 degrees and printed 40 degrees of overhang. In the second part I tilted the nozzle to about 40 degrees and was able to achieve 80 degrees of overhang. Looking at the picture it seems that 90 degrees should be possible, too.
Video of the test print
Unfortunately the nozzle tilted about 2 layers too early, so there are small artefacts (layers moved to the side a bit):
Now I am going towards 90 degrees of overhang, but it takes a bit longer as I have to generate all the code manually angry smiley (or is there already a slicer for 5 axis 3d printers ??? smiling bouncing smiley )
Edited 1 time(s). Last edit at 06/18/2014 09:43AM by Fabricate.
A2
Re: 4 axis printer for more overhang
June 18, 2014 10:26AM
Awesome, much fun to watch it rotate thumbs up
I hope you figure out a solution!
I would like to see how you have your mechanics configured.
June 18, 2014 12:56PM
A2
And the software - both the firmware and the slicer.
June 18, 2014 01:46PM
jbernardis
Fabricate
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
June 18, 2014 03:24PM
A2
Thanks winking smiley !
A2
I can deal with some pics grinning smiley !
jbernardis
Well, it is just a proof of concept at the moment. There is no slicer (at least I could not find one) so I am writing the code for test objects by hand. And the firmware is just standard marlin where I added a new command.
A2
June 18, 2014 04:19PM
Clever implementation, I like it thumbs up
In college I started with punch cards, then paper tape, then programming gcode-mcode on a console, so I appreciate the effort that you have put into your project. Hopefully one of the slicer gurus will find interest in your endeavor, and sort it out!
Not knowing what you design intent is..... I'm wondering if the Y-axis is causing the issue, or the Y-axis and the parallelogram interaction. Are you printing planer sections in an arc, or are you trying to print a segmented arc?
segmented arc
Edited 1 time(s). Last edit at 06/18/2014 04:21PM by A2.
open | download - ScreenHunter_606 Jun. 18 15.59.jpg (21.6 KB)
open | download - ScreenHunter_607 Jun. 18 16.10.jpg (18.6 KB)
June 18, 2014 04:48PM
A2
Thank you smileys with beer !
A2
Yea, I hope so, too! But there has to be a good theoretical foundation, as you do not have a fixed layer height any longer! This will be a longer way to go, but looks very promising for me!
A2
I did not have the intention to print an arc, just two segments with two different angles. The jitter (or layer offset) comes from the early tilting (about 2 layers too early) and because the center of rotation is in the center of the previously layed layer (this was maybe not the best design decision, but I was assuming that this will give the best results).
I am trying to print something like your design in picture one (planer sections in an arc). I just need the base as my heater bloc is much too big to allow tilting at 45 degrees without touching the printbed. I am going to build a custom heater with nichrome wire to deal with that!
A2
June 18, 2014 05:33PM
Fabricate
As I was drawing it to scale, I could see where some issues like overlap will arise, the layer interface is constantly changing.
June 18, 2014 05:35PM
The perimeters could be slice in seperation similar to sparce infill, with infill being sliced as a somewhat seperate entity, filling based upon shape rather than perimeter layer.
June 18, 2014 10:10PM
@Fabricate: Awesome! I have a student working on a 5DOF slicer or more specifically a non-planar slicer to be used with the Sextupteron.
On a side note: I am contemplating making a program that will take an STL and perform a transformation so that it can be used with standard slicers. (Essentially, it would make the nonplanar layers planar.) The program would need a second part that could perform the inverse transformation on the gcode.
ConceptFORGE
Wally, GUS Simpson, LISA Simpson, THOR Simpson, Sextupteron, CoreXZ
June 19, 2014 06:17AM
nicholas.seward
Hi Nicholas!
This is great news cool smiley , in what state is the 5DOF slicer at the moment? I would like to see this slicer as soon as possible, as well as your Sextupteron! Is there some code available that I can use for some in depth testing of the 4th axis. I would love to test anti-aliasing for low-angle top surfaces (like the top of a sphere for example).
Do you already have a working prototype of your Sextupteron? I love that design!
June 19, 2014 06:31AM
MrDoctorDIV
Yea, this is a good idea (and will speed up printing time). So the perimeters should be sliced by the shape of the object and the infill by constant z-layers.
But what if we can really print 90 degrees of overhang (even tilting the nozzle some degrees more should be possible, so I guess this is not a real limit)? Then we have to apply a more advanced bridging strategy! I guess there are some more difficulties that have to be solved, but I see a lot of potential in this approach!
June 19, 2014 12:18PM
Two Sextupterons are slated to be completed in October.
The slicer is only in the geometry acquisition stage right now. It will accept two main parameters: max angle of nozzle relative to the print surface normal and max angle of nozzle relative to the bed normal. I don't know if it will be generalized to deal with 4D printing. It also won't worry about bridging and anti-aliasing the top surfaces at first. It will only worry about increasing allowable overhangs.
ConceptFORGE
June 21, 2014 05:30AM
Wahou ! That s Nice ! How do you manage the fourth axis in the firmware ?
June 22, 2014 09:54AM
@nicholas.seward: Very, very exciting stuff. I am looking forward to seeing both the sextupterons and the slicer!
Do you teach a school for big kids too? I want to be a part of it!
Edited 1 time(s). Last edit at 06/22/2014 09:55AM by Thorp.
June 24, 2014 04:24PM
Don't forget you now have the potential to collide the head with previously printed material ... hasn't the definition of "printable" just got a lot more complicated?
Good stuff though!
Cheers,
Robin.
June 25, 2014 03:53AM
nicholas.seward
Great! Can't wait to see them!
nicholas.seward
I understand this, I am also more looking into printing larger overhangs.
June 25, 2014 03:57AM
victorjung
Thank you! At the moment it is just a proof of concept so I have hacked marlin to control the fourth axis. Unfortuantely I did it wrong so the tilting is executed a bit too early.
If you know a 5 axis firmware, this would be great. Otherwise I will start to implement it correct in Teacup (or maybe Repetier).
June 25, 2014 04:01AM
Zedsquared
Good stuff though!
Cheers,
Robin.
Thank you for your hint Robin!
I should have stated that this is just a proof of concept at the moment. I was taking care that nothing of the mechanics will go below the tip of the nozzle, the only issue remaining is the shape of the nozzle and the heater block. In a second iteration I will make a custom heater block with nichrome wire, that won't collide with the printed part.
June 25, 2014 08:31AM
I know Repetier can have 5 extruders, I don't know anything about programming them as axis.
Also looks like aprinter can add axis "easily."
June 25, 2014 01:29PM
MrDoctorDIV
Sounds interesting! Thank you for the hint, I will have a look at aprinter, too!
I have heard that Teacup is also on the way towards 5 axes support. It seems that there is already some development going in the right direction.
August 05, 2014 07:22PM
Thats incredible! congratulations!
I think you could use a CNC router software to control it with the 4th axis like mach3 or something
Did you build the nozzle or did you get it?
Thanks!
