Parameters
Posted by EdSells
Parameters
July 19, 2007 01:25PM
Hi guys!
Adrian and I have completed a page on the wiki with documentation for all
the parameters used in the code. We've included the values we're currently
using for Darwin, and it'd be pretty fascinating to compare the values we're
all using... so if you wanna add your own columns up there that'd be cool:
How to build a RepRap -> Tweaking.
OK,
eD
_______________________________________________
Developers mailing list
Developers@reprap.org
[reprap.org]
Re: Parameters
July 19, 2007 01:58PM
[en.wikipedia.org]) tongue sticking out smiley
Re: Parameters (and the tweaking thereof)
July 19, 2007 04:58PM
Ed, you just demonstrated that English is context-sensitive :-)
Try [catb.org] or
[foldoc.org]; for more Reprap-relevant definitions!
Jonathan
Re: Parameters
July 21, 2007 04:28PM
Thanks for the parameter tweaking terminology guys...!
How's this: methamphetamine or no methamphetamine, I'm twiddling on. And I'm
not talking punding, easter egging or shotgun debugging, I'm talking
factoring the fudge and cutting the slop - I guess frobnication. Coz until
_this_ phase is nailed, I guess Darwin's slightly (and this is my favourite)
'twacked' ;-)
(You know I'll have to crowbar all this into my thesis).
eD
-----Original Message-----
From: developers-bounces@reprap.org [mailto:[email protected]]
On Behalf Of RepRap Forum Mailer
Sent: 19 July 2007 18:59
To: developers@reprap.org
Subject: Re: Parameters
Author: Forrest Higgs
Username: Forrest Higgs (206-55-252-246.adsl.sta.mbay.net)
Forum: Developers
Link: [forums.reprap.org]
Approved: Yes
[reprap.org]
[reprap.org]
Re: Parameters
September 10, 2007 10:36AM
I've just updated the code to add a debug value in reprap.properties file to turn on and off writes to System.out. This is distinct from the commsDebug flag, which (as before) send all communications to System.out.
Also added an extruder reverse time to the properties file to reverse the extrude motor for a short time when it is turned off. This feature isn't in the code yet.
When you next update via svn you should check the differences between your local reprap.properties file and reprap.properties.dist in the lib directory (it's easier to run diff if you alphabetically sort the files first - the order of items in them doesn't matter). Add the three lines in the new file to your local copy.
best wishes
Adrian
[reprap.org]
[reprapltd.com]
