At a guess d8 and d9 are shorted together somewhere (or what ever pins your using)
remove the hot ends and heated bed
Stick a multimeter into D9 and turn on the hot end, do you read 12v?
now check D8 is it also 12v?
If so you probably have a short between d8 and d9 somewhere...
unplug your ramps (while it all off) and check Resistance between the d8 and d9 ramps pins that plug into the mega connector, there shouldn’t be any connection
See pins labelled 8 and 9, top row, end of first connector on the left (
image)
If the ramps look ok, check the same pin connectors on the mega
Could also be at the mosfet end. if your making your own board. Don't connect the back of the mosfets together electrically on the heat sink.
Edited 3 time(s). Last edit at 09/05/2014 06:33AM by Dust.
