Quoting RepRap Forum Mailer :
>> We'd also have to change that so that the host still tells X it's
>> the master,
>> but then _X_ tells Y it's the slave (the ring should make that
>> trivial to do).
> It's doable, but it might be simpler if X tells the host "I'm done
> being master" (in the same packet it tells the host that move is
> completed?) , and then the host tells Y to be master? That way the
> host is in some sense more "in control" of the action, and
> (significantly!) CommDebug will show all that action for
> troubleshooting. If we have PICs talking among themselves, as you
> propose, we'll need a "network monitor" board that sniffs every TX
> output at high impedance, or something, just so we can get a network
> traffic capture of all traffic...
The problem with that is this situation: X is master and is drawing
line 1. It also has line 2 buffered internally waiting to go. X has
told Y that Y is the slave. X finishes line 1. It queues up a
"finished line 1" packet to the host and immediately starts drawing
line 2 with Y still the slave as before. No traffic at all has to go
round the ring between the end of line 1 and the start of line 2, and
that is the ideal we want to achieve.
The "finished line 1" signal ambles round the ring in a leisurely
fashion as line 2 is being drawn, and the host then sends a "draw line
3" packet to X, the transmission speed of which is equally
non-time-critical.
The alternative (and this is probably even better) would be that when
the machine is initialised the host tells X it's the master and Y it's
the slave until further notice. I think in practice, though any PIC
could become master in principle, the host would always tell X to be
master for an entire run. That way there is no inter-PIC comms (which,
as you quite rightly say, would be a real pain to debug).
> BTW, this change will probably make Eric M. very happy, since it
> appears that the delays between segments are a major issue for his
> machine at the moment!
Yes - Ed's stalled too on refining the parameters for Darwin, as fixing
this problem will make all lines a lot smoother, and - until that
happens - there's no point in trying to find maximum reliable plotting
speeds and the like.
Best wishes
Adrian
Dr Adrian Bowyer
staff.bath.ac.uk]
reprap.org]
_______________________________________________
Developers mailing list
Developers@reprap.org
reprap.org]
