3D Printer Design (Thoughts) December 08, 2014 06:22PM |
Re: 3D Printer Design (Thoughts) December 11, 2014 02:56AM |
Re: 3D Printer Design (Thoughts) December 11, 2014 03:17PM |
Re: 3D Printer Design (Thoughts) December 11, 2014 06:48PM |
Re: 3D Printer Design (Thoughts) December 12, 2014 02:36PM |
Re: 3D Printer Design (Thoughts) December 13, 2014 06:52AM |
Re: 3D Printer Design (Thoughts) December 13, 2014 01:20PM |
Re: 3D Printer Design (Thoughts) December 14, 2014 02:57AM |
Re: 3D Printer Design (Thoughts) December 14, 2014 09:03AM |
Re: 3D Printer Design (Thoughts) December 15, 2014 09:18AM |
Re: 3D Printer Design (Thoughts) December 21, 2014 04:50AM |
Re: 3D Printer Design (Thoughts) February 03, 2015 10:16PM |
Re: 3D Printer Design (Thoughts) February 04, 2015 11:08PM |
epicepee
Just wanna throw out that an 8-bit MCU can run a delta just fine. Lots of people, including myself, use RAMPS to run deltas.
Re: 3D Printer Design (Thoughts) February 06, 2015 11:48AM |
AndrewBCN
Thank you for your refreshingly honest post! There is a lot of FUD being spread here in this forum about using the ubiquitous Arduino Mega 2560 + RAMPS 1.4 combo to control linear delta printers. Something I always thought was quite odd was that when Johan Rocholl designed first the Rostock and then the Kossel lines of printers, he was using 8-bit MCUs so I couldn't understand why people insisted that a 32-bit controller was necessary.
I can quite understand that if you are running a linear delta printer at very high speeds, the 8-bit MCU can run out of cycles to perform the necessary calculations, but surely this is not the case when running a delta printer at normal printing speeds?
