Frame stability, higher acceleration and crazy cooling January 08, 2015 05:15PM |
Re: Frame stability, higher acceleration and crazy cooling January 08, 2015 07:06PM |
Admin Registered: 16 years ago Posts: 13,886 |
Re: Frame stability, higher acceleration and crazy cooling January 08, 2015 07:39PM |
Re: Frame stability, higher acceleration and crazy cooling January 09, 2015 02:29AM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Frame stability, higher acceleration and crazy cooling January 09, 2015 09:57AM |
Re: Frame stability, higher acceleration and crazy cooling January 09, 2015 12:16PM |
Re: Frame stability, higher acceleration and crazy cooling January 09, 2015 03:44PM |
In terms of G-forces, it's about 8.15G, or roughly 1G less than a rocket bound for the ISS. Not impossible, but not reasonable.Quote
691175002
To put the problem in perspective, reaching a maximum speed of 2000mm/s from rest during a linear movement of 50mm requires an acceleration of 80,000mm/s^2. It is very difficult to properly convey just how large that number really is.
Re: Frame stability, higher acceleration and crazy cooling January 09, 2015 06:35PM |
Unreasonable is one way of putting it - I'm pretty sure that if you tried to accelerate a metal extruder at 8G the heat-break would snap in half. Especially with a long melt zone and multiple heater cartridges.Quote
Feign
Re: Frame stability, higher acceleration and crazy cooling January 10, 2015 07:39AM |
Re: Frame stability, higher acceleration and crazy cooling January 10, 2015 08:27AM |
Re: Frame stability, higher acceleration and crazy cooling January 11, 2015 03:23AM |
Re: Frame stability, higher acceleration and crazy cooling January 11, 2015 03:21PM |
Re: Frame stability, higher acceleration and crazy cooling January 11, 2015 09:24PM |
Re: Frame stability, higher acceleration and crazy cooling January 14, 2015 05:48PM |
Re: Frame stability, higher acceleration and crazy cooling January 22, 2015 04:20PM |
Re: Frame stability, higher acceleration and crazy cooling January 30, 2015 02:41AM |
Re: Frame stability, higher acceleration and crazy cooling January 30, 2015 10:58AM |
Re: Frame stability, higher acceleration and crazy cooling February 07, 2015 03:32PM |
Re: Frame stability, higher acceleration and crazy cooling February 07, 2015 03:59PM |
crispy1
Second, bowden systems have hysteresis that results in excess plastic in corners and flow starvation in acceleration regions. In theory you can compensate for this with a simple first order approximation in the firmware but nobody's done it successfully yet on RepRap firmware.
Re: Frame stability, higher acceleration and crazy cooling February 07, 2015 05:00PM |
foamstone
RAMPS 1.4 (firmware may get changed or get re-written as needed). If performance is a problem, I'll move up
DRV8825 stepper controllers with heat sinks and fans
24V @ 100A max power (yes, almost 2.5kW), although this is definitely overkill.
Liquid cooling (H2O, oil, or NH3)
Re: Frame stability, higher acceleration and crazy cooling February 10, 2015 11:01AM |
crispy1
The limiting factor turns out to be the rate at which you can feed and melt the plastic. Extrusion force and melt chamber pressure climb rapidly as feedrate increases. At some point you're going to a) strip the filament b) explode part of the bowden system (don't use PTC fittings) or c)or explode the hotend. I think this is going to be your main limiting factor.
Re: Frame stability, higher acceleration and crazy cooling February 10, 2015 03:26PM |
Re: Frame stability, higher acceleration and crazy cooling March 09, 2015 01:58AM |
Re: Frame stability, higher acceleration and crazy cooling March 09, 2015 03:46AM |
Re: Frame stability, higher acceleration and crazy cooling March 09, 2015 12:42PM |
Re: Frame stability, higher acceleration and crazy cooling March 15, 2015 06:58PM |
