LCD graphics display 128x64
Posted by garaguido
January 31, 2015 10:48AM
Here are som sreen issiues , that i found using my LCD graphics display (see foto's).
One of the things that by me occured , by using the LCD is , letters "..mm" above the others .
Changing the hight from caracters will do the trick ?
And the sound of the beeper by clicking , can i dim this and how ?
My LCD display is a HE3D from Aliexpress
Is there sombody who nows the answer ?
open | download - P1070623.JPG (123.8 KB)
open | download - P1070625.JPG (134.8 KB)
Re: LCD graphics display 128x64
January 31, 2015 08:34PM
It looks like your display is overlapping the characters "mm:" and "+00", trying to display 17 characters in the space of 14. Hard to help further without knowing what you're using to drive the display (Arduino, etc.) and a sample of the programming.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
February 01, 2015 09:36AM
My motherboard is a Melzi 2.0 board (Atmega 1284 16mHz) with Marlin _1 firmware and U8glib for driving the LCD .
Is there perhaps a config setting problem ?
I have contacted Oliver Kraus the author of the U8glib , an text me that this is not his problem , his software works fine.
Perhaps a Marlin problem ?
Ano
February 04, 2015 10:37AM
I have the same issue, also using 128x64. My setup: RAMPS1.4 with Arduino and Marlin Software + U8glib
Prusa i3 Rework (from Replikeo.com) & original Prusa i3 MK2 (from shop.prusa3d.com) << the MK2 definitely is worth the higher cost!
Print Troubleshooting Guide // Visual troubleshooting guide
February 04, 2015 11:17AM
Hereby the foto from the problems on the screen .
Is this the same thing by jour screen , a screen type issue perhaps?
Have looking in the "doglib.cc" file but i can not found any faulty caracter setting or templates .
I am not a C++ specialist , have some degree of programming expierience with "dbase"programming " but C++ is not my piece of cake.
Let's hope , perhaps is there some one with a proper solution , but this is not a mayor problem for using the LCD now.
open | download - P1070622.JPG (139.1 KB)
February 04, 2015 11:21AM
Is this the samething by jour screen , a screen type issue perhaps?
Have looking in the "doglib.cc" file but i can not found any caracter setting or templates .
Lets hope perhaps is there someone with a proper solution , is not a mayor thing for using the LCD now .
Ano
February 04, 2015 01:06PM
Yap, exactly the same. I didn't consider this as a problem, because I still can read what is meant, but I thought this is the case for everyone.
So, if there is a fix, I would gladly apply it. Although I would not really invest time in finding it on my own, because my other printer related
problems are much more pressing ^^
February 04, 2015 01:55PM
Check the settings in dogm_lcd_implementation.h...
#define USE_BIG_EDIT_FONT                // save 3120 bytes of PROGMEM by commenting out this line
#define FONT_STATUSMENU u8g_font_6x9
#define FONT_MENU u8g_font_6x10_marlin
// DOGM parameters (size in pixels)
#define DOG_CHAR_WIDTH         6
#define DOG_CHAR_HEIGHT        12
#ifdef USE_BIG_EDIT_FONT
  #define FONT_MENU_EDIT u8g_font_9x18
  #define DOG_CHAR_WIDTH_EDIT  9
  #define DOG_CHAR_HEIGHT_EDIT 18
  #define LCD_WIDTH_EDIT       14
#else
  #define FONT_MENU_EDIT u8g_font_6x10_marlin
  #define DOG_CHAR_WIDTH_EDIT  6
  #define DOG_CHAR_HEIGHT_EDIT 12
  #define LCD_WIDTH_EDIT       22
#endif
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
February 04, 2015 02:22PM
Thanks David
I will do what try-outs with changing the pixel hight in the big edit font
Guido
February 04, 2015 02:29PM
I Have a Heacent prusa i3 with Melzi 2.0 board
Hereby are the foto's .
My prints are verry wel and accurated , at 0.01mm.
I use mostly PLA on heated bed with ABS juice
open | download - P1070617.JPG (282 KB)
open | download - P1070615.JPG (244.8 KB)
Ano
February 04, 2015 03:39PM
MindRealm
#else
#endif
I think I have another version of this then. My file only says:
#define DOG_CHAR_WIDTH_LARGE   9
#define DOG_CHAR_HEIGHT_LARGE  18
#define START_ROW              0
February 04, 2015 04:35PM
Your settings are right there... Try changing the following lines:
to
#define DOG_CHAR_WIDTH_LARGE   6
#define DOG_CHAR_HEIGHT_LARGE  12
Note the 2:1 height to width ratio. 8 and 16, 7 and 14, etc. should work as well.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
February 05, 2015 11:20AM
David
My file is the same version of you.
I have tried with this numbers that you sugested and notting will changed it is still the same overshoot therefor i have changed my text in the language.h module
from Xsteps/mm to Xst/mm and this is working well , i can read the numbers again.
In the language .h module can you change the language and the name of your machine , thats displayed op the first page from the LCD , if you want to .
There are also 11 languages available myn is number 11 (Dutch)
Guido
February 08, 2015 09:17AM
Tne issue mabe the possition of the text you are placing' check the code where is written the information.
