Linear electric motors, and high speed printing in general May 26, 2015 03:13AM |
Re: Linear electric motors, and high speed printing in general May 26, 2015 06:48AM |
Re: Linear electric motors, and high speed printing in general May 26, 2015 11:39AM |
Re: Linear electric motors, and high speed printing in general May 26, 2015 12:38PM |
Linear motors are not well suited to DIY or to delta printers for several reasons.
Linear motors require pneumatics in vertical applications since they provide no resistance to motion when unpowered and fighting gravity is an enormous waste of power.
DIY is not an option. Getting accurate positioning from a motor is difficult - you need to use a lot of tricks to avoid cogging (ironless motors are not well suited to this application).
Linear motors also create extremely strong attractive forces since you have a stack of magnets next to a block of iron. A linear motor suitable for 3d printer use would likely create >50lb of attractive force. This makes assembly dangerous and requires expensive linear bearings to manage.
Even if you get the thing built, you still need to figure out the encoder/drive.
There are actually plenty of ways to get sufficient acceleration for 3d printing without resorting to linear motors. Servos, hybrid servos and closed-loop steppers should all be sufficient and much more cost effective.
Re: Linear electric motors, and high speed printing in general May 26, 2015 02:38PM |
Re: Linear electric motors, and high speed printing in general May 26, 2015 03:43PM |
Re: Linear electric motors, and high speed printing in general May 26, 2015 04:35PM |
frankvdh
AliExpress is your friend when it comes to supplies and prices... 12V linear motors start about $21 for 200mm/1000N.
There's no reason you couldn't have a hybrid... a stepper for the vertical axis (which doesn't move much or fast), and linears for X,Y.
Re: Linear electric motors, and high speed printing in general May 26, 2015 05:14PM |
Admin Registered: 16 years ago Posts: 13,886 |
Re: Linear electric motors, and high speed printing in general May 26, 2015 05:59PM |
Indeed, 3 to 6 months... and what will you be using to drive your PLA filament, a Greg's Wade's geared extruder?Quote
691175002
I am actually building a 3d printer with linear servos, but it will probably take another 3-6 months to finish.
Re: Linear electric motors, and high speed printing in general May 26, 2015 06:37PM |
AndrewBCN
LOL!
Re: Linear electric motors, and high speed printing in general May 26, 2015 07:16PM |
Re: Linear electric motors, and high speed printing in general May 26, 2015 07:29PM |
Linear servos are actually great for 3d printing if you ignore their astronomical cost and complexity.
I'll admit its a pretty silly idea. I found the linear stages on ebay and the auction was so cheap I couldn't help myself. After they arrived I had to come up with a project to justify their purchase. Extruder will be an E3D Chimera.
It should actually be a pretty straightforward build since the linear stages are complete and self contained. I pretty much just need to bolt them together at right angles.
Re: Linear electric motors, and high speed printing in general May 26, 2015 08:17PM |
Do you have examples of linear induction motors being used in this kind of application? I was under the impression they are not viable for positioning. I haven't even seen a linear induction motor sold in a linear stage or coupled with a high resolution encoder. In high stiffness positioning applications you generally see only iron core motors.
dc42
Be aware that for standard FDM printer technology, the limiting factor isn't how fast you can move or accelerate the head, it's how fast you can extrude plastic and have it solidify where you want it. I can move the head of my delta printer at 500mm/sec, but I can't print at that speed.
(words, linear motor printer)
AndrewBCN
Check the thread Elements of 3D printer design in this forum (just a few threads down). There is much more to designing a 3D printer than simply solving the problem of linear/polar 3D motion.
Also there are may ways to get linear motion in a machine, stepper motors + belts or stepper motors + threaded screws have been traditionally used in RepRap 3D printers because they are inexpensive, simple to understand, easy to maintain and do the job.
Using linear motors is another possible solution of course, but the way I see it, it's much like a "Rube Goldberg machine" solution.
Re: Linear electric motors, and high speed printing in general May 26, 2015 09:18PM |
Re: Linear electric motors, and high speed printing in general May 27, 2015 03:10PM |
Re: Linear electric motors, and high speed printing in general June 15, 2015 07:58PM |
Re: Linear electric motors, and high speed printing in general June 16, 2015 10:07AM |
wingmaster
If you balance the weight of the 3d printer head with some counter ballast, then the motors on a delta printer would not need to create force to hold up the weights. The only force they have to create is to accelerate and de-accelerate the mass.
Sadly the amount of it mass need to move doubles in this case. But because no power is wasted in lifiting weight, all power can do to move mass.
Re: Linear electric motors, and high speed printing in general December 07, 2017 02:44AM |
DIY is not an option. Getting accurate positioning from a motor is difficult - you need to use a lot of tricks to avoid cogging (ironless motors are not well suited to this application). Linear motors also create extremely strong attractive forces since you have a stack of magnets next to a block of iron. A linear motor suitable for 3d printer use would likely create >50lb of attractive force. This makes assembly dangerous and requires expensive linear bearings to manage.
I have a sneaking suspicion that accelerating a hotend at 5G will either snap the heatbreak or shear the bowden tube.
Re: Linear electric motors, and high speed printing in general December 07, 2017 10:31AM |
Re: Linear electric motors, and high speed printing in general December 07, 2017 05:32PM |
Re: Linear electric motors, and high speed printing in general December 08, 2017 02:56AM |
Re: Linear electric motors, and high speed printing in general December 08, 2017 03:33AM |
Re: Linear electric motors, and high speed printing in general December 08, 2017 08:58AM |
Re: Linear electric motors, and high speed printing in general December 08, 2017 11:16AM |
janbbeck
That is beautiful work!
I am working on a similar system:
[sites.google.com]
How did you do your sheet metal?
On cooling, have you looked into the Berd-Air? The guys on the Zesty Nimble group say very good things about it.
M_Xeno
IMHO, linear motors are fascinating, but would be interesting for 3D printing only if they could radically simplify mechanical architecture, or electronics, which is not the case.
Re: Linear electric motors, and high speed printing in general December 08, 2017 05:20PM |
janbbeck
[sites.google.com]
Nice project, the Granite Devices drives are a neat touch. I'm using VIX-IH drives, but those things must be twenty years old and there is no way to monitor the position/error of the servos for tuning which will probably be an issue.
I designed the entire printer in solidworks and had local shops do all the fabrication. I've done all my previous personal projects myself, but I wanted to try this instead to see how the quality/cost/convenience compares. Overall it was a very good experience and I learned a lot.
I'll look into using a pump and tubing to bring air, but unfortunately I don't have a good place to mount the pump.
M_Xeno
I don't think anyone can pretend linear motors make sense in a 3d printer, but they are certainly fun. My primary goal was actually dimensional accuracy, with speed being more of a side bonus. My frame weighs 80lb and every alignment is roughly +-0.001" against a granite square.
A lot of hobby printers have problems printing square which is inconvenient for some functional prints (gears in particular).
Re: Linear electric motors, and high speed printing in general December 08, 2017 06:01PM |
Re: Linear electric motors, and high speed printing in general December 08, 2017 06:09PM |
I also come from a CNC background so I agree with you completely. Sometimes I joke that I've spent more on metrology than machine tools.
Unfortunately the FDM process is probably too slow and sloppy to make use of the performance linear servos can achieve. I hope that I can print somewhat faster than average while also producing surface finishes that are slightly better than average, but I'm not expecting linear servos to ever be a cost effective or practical alternative to existing designs.
Re: Linear electric motors, and high speed printing in general December 08, 2017 06:11PM |
Re: Linear electric motors, and high speed printing in general December 12, 2017 12:56PM |
Re: Linear electric motors, and high speed printing in general December 12, 2017 06:14PM |
I've been working on a blog but the updates have been quite sporadic. Eventually I'll review all the posts and turn it into a proper build log.
[www.everythingbends.com]
I browsed your site and actually found the printed bellows to be very interesting, as in my experience custom bellows tend to be expensive and hard to source. Lasers are fun but I hope to never find myself in a situation where an interferometer is necessary.
