ESP8266 Duet web interface for any board November 10, 2015 01:44AM |
Re: ESP8266 Duet web interface for any board November 10, 2015 01:28PM |
Re: ESP8266 Duet web interface for any board November 10, 2015 03:50PM |
Re: ESP8266 Duet web interface for any board November 11, 2015 04:49AM |
Re: ESP8266 Duet web interface for any board November 12, 2015 01:58PM |
Re: ESP8266 Duet web interface for any board November 12, 2015 02:48PM |
Re: ESP8266 Duet web interface for any board November 12, 2015 04:53PM |
Re: ESP8266 Duet web interface for any board November 12, 2015 07:00PM |
Re: ESP8266 Duet web interface for any board November 12, 2015 08:14PM |
Re: ESP8266 Duet web interface for any board November 13, 2015 04:34AM |
toxuin
@dc42 There are several commands that are expected to come in JSON format. And as far as I know only RepRapFirmware does that. We could code some workarounds though (like storing macros in ESP flash, lol).
And BTW, ESP8266 has 5V-tolerant inputs, so you'll only need a voltage regulator (or a 3V line which is present on RADDS), no need to shift all the levels.
Re: ESP8266 Duet web interface for any board November 13, 2015 03:30PM |
Re: ESP8266 Duet web interface for any board November 14, 2015 05:09PM |
Re: ESP8266 Duet web interface for any board November 14, 2015 05:54PM |
Re: ESP8266 Duet web interface for any board November 14, 2015 05:59PM |
Re: ESP8266 Duet web interface for any board November 16, 2015 06:21PM |
Re: ESP8266 Duet web interface for any board November 23, 2015 02:37AM |
Re: ESP8266 Duet web interface for any board November 27, 2015 01:26AM |
Re: ESP8266 Duet web interface for any board November 28, 2015 07:36AM |
Re: ESP8266 Duet web interface for any board November 28, 2015 06:24PM |
Re: ESP8266 Duet web interface for any board November 28, 2015 08:34PM |
Re: ESP8266 Duet web interface for any board November 29, 2015 12:29AM |
Re: ESP8266 Duet web interface for any board November 29, 2015 12:36AM |
Re: ESP8266 Duet web interface for any board November 29, 2015 01:22AM |
Re: ESP8266 Duet web interface for any board November 29, 2015 03:47AM |
toxuin
Thanks for your observations! Apparently something has changed in how ESP8266 webserver handles .gz files – now it detects gzipped files and sends "Content-Encoding: gzip" on its own. ESPRINTER code was doing the same job so there were two content-encoding headers in every response and Chrome seems to not like it (Safari is okay with that though).
Anyways, I've pushed some small fixes to the repo and tested the thing with Chromium 45.0.2454.101 and Firefox 26. Seems to work.
Re: ESP8266 Duet web interface for any board November 29, 2015 06:29AM |
Re: ESP8266 Duet web interface for any board November 30, 2015 12:28AM |
Re: ESP8266 Duet web interface for any board November 30, 2015 04:53AM |
Re: ESP8266 Duet web interface for any board November 30, 2015 08:04AM |
Re: ESP8266 Duet web interface for any board November 30, 2015 09:58AM |
dc42
You can iterate different settings without uploading a new config.g every time. Just 'print' the new config.g. The network settings won't get updated, and you will get an error from the M563 command(s) unless you delete the existing tool(s) first using e.g. M365 P0 D-1 H-1, but everything else should work.
Re: ESP8266 Duet web interface for any board November 30, 2015 03:51PM |
