Re: Controlling a RepRap with ESP8266 and no Arduino November 18, 2016 05:46AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 19, 2016 06:24AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 19, 2016 03:10PM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 21, 2016 04:50AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 21, 2016 10:36AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 21, 2016 12:45PM |
// Create a down-counting triangle wave. if (--counter == 0) counter = period; // If the PWM should be active then set the bit in the I2S output data. if (duty >= counter) out |= PWM_BIT;
Re: Controlling a RepRap with ESP8266 and no Arduino November 21, 2016 01:02PM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 22, 2016 04:16PM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 22, 2016 05:54PM |
Hubberthus
Did you know that the only firmware supporting JSON-style printout is RepetierFirmware? And that is not even a fixed standard, according to the Wiki.
Re: Controlling a RepRap with ESP8266 and no Arduino November 22, 2016 07:15PM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 23, 2016 03:58AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 24, 2016 06:08AM |
Hubberthus
It's no use in starting to create an ESP firmware for ESP8266 when we have now the ESP32.
This "fun with ESP8266" is pretty good to reveal what problems I can run into with an actual ESP32-exclusive firmware, and what to use.
Re: Controlling a RepRap with ESP8266 and no Arduino November 24, 2016 06:44AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 24, 2016 07:58AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 30, 2016 06:46AM |
Paliap
The program then runs round the polygons from quad to quad linking the ends up.
When you now have a set of polygons for RepRap to outline and to fill in. But a list of line segments is a very non-robust representation of a polygon for operations like zig-zag infill, and also it's hard to offset. You need to offset the polygons to make smaller ones inside because the stream of polymer is not zero thickness, so - for example - you need to run the write head slightly inside the polygon you're going to create to outline it. Then the zig-zag infill needs to be a zig-zag in a smaller polygon inside the first offset polygon too.
Re: Controlling a RepRap with ESP8266 and no Arduino November 30, 2016 06:53AM |
JamesK
Paliap
How did we get on to writing a new slicer? Sounds like fun, just not sure how we got here.
Re: Controlling a RepRap with ESP8266 and no Arduino November 30, 2016 06:59AM |
Re: Controlling a RepRap with ESP8266 and no Arduino November 30, 2016 09:06AM |
Hubberthus
@lhartmann - Weeell... It surely can work, I won't say it can't. But I'll rather stick to ESP32 when it comes to creating a firmware for the "family".
Re: Controlling a RepRap with ESP8266 and no Arduino November 30, 2016 11:59AM |
lhartmann
ESP32 is out already, both as ESP12-like and NodeMCU-like. For that price, though, we would be better off with an Orange Pi Lite. The advantages of the *Pi would be proper fast SD, filesystem, webserver, and we would be able to run octoprint. All we would need to code is a gcode-capable, I2S, motion-control backend. Apart from timelapses, though, we can do pretty much everything on an ESP8266.
I kinda loved the Orange Pi Zero form-factor, that would be great for an embedded solution and is pretty much the same price of a NodeMCU. Unfortunately the Orange Pi Zero's I2S pins are not available (used internally for wifi-enable and something else).
Re: Controlling a RepRap with ESP8266 and no Arduino November 30, 2016 12:24PM |
Re: Controlling a RepRap with ESP8266 and no Arduino December 01, 2016 05:52PM |
Re: Controlling a RepRap with ESP8266 and no Arduino December 01, 2016 10:07PM |
Re: Controlling a RepRap with ESP8266 and no Arduino December 02, 2016 09:04AM |
Re: Controlling a RepRap with ESP8266 and no Arduino December 02, 2016 10:31AM |
Hubberthus
Regarding the SD-card problem: (...) If you can harness the power of primary SPI, and do the timing from SW so you don't interfere with the SPI flash, then you're a master Jedi, and I'll bow down before you!
Hubberthus
Whoah, a gcode compression! Another fine topic. (...) With everybody creating their own format, it will soon be a huge mess.
Hubberthus
And of course in the meatime I was working with my ESP8266+Arduino core+Marlin+ESPrinter+DuetWifi combo. I had to merge in the DuetWifi's webpage because ESPrinter is 1 years old, and its code is buggy.
Hubberthus
However I won't continue the Marlin port, would be just a waste of time.
When I will receive the ESP32, and the holidays are over, then I will continue with digging into the module.
And the FreeRTOS-based modular 3D printer firmware should be started out somehow.
Re: Controlling a RepRap with ESP8266 and no Arduino December 03, 2016 09:49AM |
Re: Controlling a RepRap with ESP8266 and no Arduino April 10, 2017 09:56AM |
Re: Controlling a RepRap with ESP8266 and no Arduino August 30, 2018 11:23PM |
lhartmann
I believe I found a way to use just an ESP8266 module to control the stepper drivers directly. This post explains how.
Background:
1. Other projects show how to use ESP01 as a wifi-serial bridge to the arduinos, but serial is still a bottleneck and wifi uploads are impractical.
2. Altough ESP8266 does 160MHz at 32bits processing (versus 16MHZ 8-bit from most Arduinos) it has insufficient realtime GPIO for controlling printers.
3. Raspberry pi shared the realtime gpio limitation, but wallacoloo still did reprap control using DMA. Nice! [www.youtube.com]
4. CNLohr did a really cool WS2812 led driver (weird one-wire serial protocol) using ESP8266 I2S audio output and DMA. [www.youtube.com]
5. I2S and SPI look very much alike, and SPI can control shift registers. Hey! Opportunity!
I got the code from CNLohr on github, modified it to output a 32 bit counter (16 bit left + 16 bit right channels) via a circular DMA buffer, and created a small PCB with four cascaded 74HC595 shift registers. wiring is simple:
- I2S Data to '595 input data
- I2S Bitclock to '595 shift clock
- I2s word clock (left/right) to '595 buffer clock.
This is what RAW I2S output signals for the counter look like: word-clock (yellow), bit clock (cyan), data (purple). Notice how LSB of data is output after the word clock rising edge. [www.youtube.com]
Fixed the offset (software shifing) to match the parallel outputs, raised the frequency a bit (just cause), plugged in the shifter board. Now this is what word-clock (yellow) and the 3LSBs (cyan=1, purple=2, blue=4) look like:
The code and the PCB: (https://github.com/lhartmann/esp8266_reprap)
What this does:
- Allows realtime bitbanging of 32 data bits via I2S and DMA.
- Demo code just outputs a 32bit counter at 185kHz sample rate.
- Reference shifter board is provided.
Limitations:
- 1MSB is actually delayed by 1 sample due to I2S signaling standard. This delay is constant so it could be compensated, but I didn't bother.
Hopes for the future:
- No extra arduino necessary, ESP would control the drivers directly.
- SDcard uploads over wifi would be feasible for large files, no more serial connection bottleneck with wifi-serial bridging.
- Browser-side slicing with slic3r and (http://www.skulpt.org). No software install required on the client!
Re: Controlling a RepRap with ESP8266 and no Arduino August 30, 2018 11:27PM |
Re: Controlling a RepRap with ESP8266 and no Arduino September 07, 2018 05:16AM |
Re: Controlling a RepRap with ESP8266 and no Arduino September 20, 2018 11:04PM |
