Re: Heat Compensated Bed Support First Test March 04, 2016 06:38PM |
Re: Heat Compensated Bed Support First Test March 04, 2016 08:31PM |
Re: Heat Compensated Bed Support First Test March 04, 2016 09:14PM |
Re: Heat Compensated Bed Support First Test March 04, 2016 11:31PM |
JamesK
Wow that's good. A maximum deviation of about .04mm? What's the temperature variation from corner to middle in the high temperature test? It occurred to me that any thermal expansion of the dti probe would add to the measured difference between the hotter centre and presumably cooler corners.
Ira
Not a clue if this might help, but if you heated the edges of the plate and let the heat carry to the center would that change the thermal stress enough to matter? If you have more than one heater connected you might try disconnecting one and see if that changes the flatness pattern.
Re: Heat Compensated Bed Support First Test April 27, 2016 11:49AM |
Re: Heat Compensated Bed Support First Test April 27, 2016 03:01PM |
Re: Heat Compensated Bed Support First Test April 27, 2016 03:31PM |
