In progress - hotend February 27, 2016 05:22PM |
Re: In progress - hotend February 27, 2016 09:52PM |
Re: In progress - hotend February 27, 2016 10:13PM |
Re: In progress - hotend February 27, 2016 10:39PM |
Re: In progress - hotend February 28, 2016 07:02AM |
Re: In progress - hotend February 28, 2016 08:39AM |
Re: In progress - hotend February 28, 2016 08:44AM |
Re: In progress - hotend February 28, 2016 08:50AM |
I asked because I saw a video the day before you posted. the reason they gave was that the blade kicks out instead of getting pulled in, so it does not bite your work peice. I'm new to lathe work, picked mine up over Chirstmas, and am learning to use it.Quote
JamesK
Yes, it's standard practice on the taig to use a cut-off tool on the back-side of the lathe.
Re: In progress - hotend February 28, 2016 09:47AM |
MechaBits
I'm wishing I had a little lathe like that but fear I would be scratching my head a little too, as most of the stuff I want to do needs a mill, the great thing about trying to cobble together a little all metal hotend is, it's quite cheap to buy all the little parts, a cheap little side project.
Re: In progress - hotend February 28, 2016 10:48AM |
Re: In progress - hotend February 28, 2016 11:55AM |
MechaBits
The problems I have run into with is heat creap with PLA. They work well for 15-30 minutes then jam. Material does not seem to make a difference, aluminum, brass, stainless, polished or not. I have not tried copper, but would expexct it to work like brass. I have also tried a 6mm stainless hex head bolt turned down for a nozzel, turned to look like the e3d nozzel. The .4 mm hole was not fun however. I have been looking for brass bolts, but local hardware places don't have them, and metric is hard enoughto find in the US. In the end I ended up with a PTFE liner.
Re: In progress - hotend February 28, 2016 12:27PM |
Re: In progress - hotend February 28, 2016 01:45PM |
Re: In progress - hotend March 01, 2016 12:28PM |
cat.farmer
Even with stainless heat break and polishing, I couldn't get pla to work consistently. The problem was the transistion zone. It would swell and stick, no matter what I did. I am working on one right now that I am excited about, once I get my new grooving tool, I can get my fins cut and get it tested.
Re: In progress - hotend March 01, 2016 12:55PM |
JamesK
cat.farmer
Ah, you were right. The 1.75mm hotend still suffers from heat creep with PLA It looks like there's still a small gap between the ptfe liner and the heat break that the swollen plastic gets jammed in. Looks like I might have to get some stainless steel rod so that I can make my own heat breaks.
Re: In progress - hotend March 01, 2016 06:10PM |
my logic suggests that once throat gets to a certain temp your into problems, so I'm wondering how having the steel throat/nozzle combo in above pic works, I dont see how having a few mm shaved from throat actually creates a break, I would have thought the thinner section of throat gets hotter quicker than thicker parts?
Re: In progress - hotend March 01, 2016 09:15PM |
Re: In progress - hotend March 02, 2016 07:57AM |
Re: In progress - hotend March 02, 2016 08:51AM |
Re: In progress - hotend March 02, 2016 09:09AM |
One of those FLIR cams would come in handy for testing and analyzing, and would make a great printing video,
ideally if it was only gripped in one or 2 points
Re: In progress - hotend March 02, 2016 09:46AM |
Re: In progress - hotend March 02, 2016 06:26PM |
Re: In progress - hotend March 02, 2016 07:03PM |
Re: In progress - hotend March 03, 2016 01:46PM |
Though I think the main issue with this heat creep is not from heat coming inwards from throat, but the whole laminated tube acting like a straw, and the filament helping with that too
Re: In progress - hotend March 03, 2016 01:49PM |
Re: In progress - hotend March 03, 2016 02:01PM |
Re: In progress - hotend March 03, 2016 02:10PM |
Anonymous User
Re: In progress - hotend March 06, 2016 04:39AM |
JamesK
Yes, it's standard practice on the taig to use a cut-off tool on the back-side of the lathe. I've never been completely convinced I understood why, but it seems to work well enough. The chuck still runs in the normal direction, the blade is upside down in the holder. I've seen it suggested that the tool holder is more stable in tension than compression.
The 3mm version has been working pretty well, so fingers crossed for this one. To be honest, I'm being far from original with this, just picking and choosing a few well tested ideas and throwing them together. At the moment the heatsink on the working version is passively cooled, but I intend to add a fan. Then it will look even more like an e3d design.
I'd like to try making some nozzles, but the (Canadian) exchange rate and the price of shipping makes brass hex stupidly expensive at the moment. I suspect it's actually cheaper to just buy Chinese nozzles
Re: In progress - hotend March 06, 2016 07:47AM |
MKSA
I too am looking to repalce the hotend I got in the Geetech kit. I am amazed, either they can't copy properly or don't think. Wrong way to secure the heater in a 6.35 hole for a 6 diam heater, thermistor at the wrong place, teflon tube goes up to the extruder nozzle, no heat barrier, cooling at the wrong place no smooth entry throat.... and a pain to remove from the extruder head.... Yet it works with PLA
Why do you use M7 for the nozzle ? Isn't the standard M6 ?
Two M3 screws would be better to squeeze the heater block to avoid warping.
I installed the thermistor on the other side of the extruder almost touching the nozzle thread , not between the heater and extruder.
I see your teflon tube at the top, how do you prevent it from getting pushed out due to the pressure ?
For the 3mm version I used a Q-tip (cotton bud) with autosol metal polish to get all the way through the bore, spinning the throats in the lathe. The 1.75mm version, the bore is too small to get into with anything I had to hand, but fortunately the stainless throat seemed to be already pretty smooth, and the aluminum upper throat has the ptfe liner so doesn't need polishing over most of its length. I machined a cone into the top of the upper throat to make filament changes easier, and I polished that with a Q-tip. The question of whether the bottom of the bore in the stainless throats is conical or flat is interesting. I had assumed it was conical as that's the easiest to do, and it's quite difficult to tell visually. However, when I cleaned up sum burs with a drill I noticed that it appeared to be biting more in the center than the edge, suggesting they may have flattened the bottom. I should find some putty or something to take an impression and see what the profile really is down there. I shaped the end of the ptfe to match a standard drill profile, so I hope it's conical down there!Quote
How did you polish the inside ? Is it conical or straight hole ?
I am also considering the use of fiber glass, silicone tubing to cut the heat transfer instead of PTFE but it need to be lined for smoothness, may be a very thin (0.1) stainless tube ?
Re: In progress - hotend March 06, 2016 12:00PM |
