multiple A4988 control April 16, 2016 09:34AM |
Re: multiple A4988 control April 16, 2016 03:11PM |
Re: multiple A4988 control April 16, 2016 05:55PM |
Re: multiple A4988 control April 16, 2016 07:56PM |
dc42
Bear in mind that the motor current will be turned off when you disable the driver, so the associated motor will not hold position.
Re: multiple A4988 control April 16, 2016 10:00PM |
Re: multiple A4988 control April 17, 2016 02:05AM |
Re: multiple A4988 control April 17, 2016 08:02AM |
lhartmann
Sharing the direction bits, and possibly using a demux like 74hc138, may be more reliable for up to 8 steppers on 5 gpio.
Re: multiple A4988 control April 17, 2016 09:14AM |
Re: multiple A4988 control April 17, 2016 09:22AM |
lhartmann
Stack the five drivers, run DIR and ENABLE in parallel, use independent STEP signals.
Same thing for the demux, use it to route the STEP signals, not the ENABLEs. 3 gpio driving the selector lines, one gpio driving the demux enable, demux outputs driving the STEP pins of each driver.
This way all motors stay powered up.
Re: multiple A4988 control April 17, 2016 10:04AM |
Re: multiple A4988 control April 17, 2016 11:26AM |
Re: multiple A4988 control April 17, 2016 11:44AM |
Re: multiple A4988 control April 17, 2016 12:34PM |
lhartmann
I have accumulated so many components over the last 15 years that I had to work a decent system to find them. I ended up buying 10 boxes with 25 divisions each, plus a lot of shoe box sized plastic boxes, stored everything there and created a Google Spreadsheet to keep track of what is where. This is simple enough, and helps me keep track of everything.
I named large boxes S01..S12, the divided boxes are given a letter each A-G, and each division is numbered 1-25. Table has 3 columns: Where, what, and how many. Something like:
A23 - Demux SN74HC138 - 10
S05 - Mini USB cable, 50cm - 1
John - Node MCU - 1 (lent item)
Searching with CTRL+F is so much easier and faster than doing so manually, but if the Internet goes down I am seriously screwed.
Re: multiple A4988 control July 06, 2016 01:46PM |
Re: multiple A4988 control July 06, 2016 02:46PM |
Re: multiple A4988 control July 06, 2016 07:47PM |
Re: multiple A4988 control July 14, 2016 09:42AM |
Re: multiple A4988 control July 14, 2016 10:16AM |
Re: multiple A4988 control July 14, 2016 10:46AM |
Re: multiple A4988 control July 14, 2016 10:55AM |
Re: multiple A4988 control July 14, 2016 11:42AM |
Re: multiple A4988 control July 15, 2016 11:37AM |
Re: multiple A4988 control July 21, 2016 03:15PM |
