heatmap of the heatbed
Posted by amigob
April 19, 2016 04:35PM
The first scan of the head bed of my Prusa.
the heater was heating up, bit I have no explanation for the right bottom corner.
here movie
it seems that sampling the temperature is so fast that you don't see it in the move.
So I can decrease the pitch for a finer grid.
P3steel DXL, with Due/RADDS/Raps128 dual Wade's extruder
Re: heatmap of the heatbed
April 19, 2016 05:18PM
I definitely need to check the adhesion of the heater in the middle of the bed
Edited 1 time(s). Last edit at 04/19/2016 05:20PM by amigob.
April 19, 2016 07:18PM
Very cool. I would never have guessed the middle being cooler than the edges.
April 20, 2016 03:27AM
That is why I made the low temperature map, I thought that something influences the measurement from outside ( light )
But in principle the low temperature measurement shows that is not the case.
I checked the heater but I couldn't real find that it was loss.
I couldn't scan the complete heat bed yet. Because of the dual extruder setup . I couldn't get to all the locations. But that is just software and configuration.
I setup my dual extruder so that the right extruder has the X offset , because of that I had 2 move my X zeroing sensor to be able to get 0.0 on the print surface.
But if I give the left extruder a minus X offset I think that will solve the problem, because then Repetier will correct for it. ( mhh difficult to explain :-) )
April 20, 2016 06:46AM
Yes, the low temperature map is pretty convincing. I'd be happy to round everything to the nearest degree and call it good.
April 20, 2016 07:40AM
We had something similar going on in a Taz printer at the Milwaukee Makerspace. A FLIR camera indicated at least 20C temperature variation across the bed surface with a cool spot right in the center. That printer had a heater glued directly to a glass bed. I'll never understand the use of glass for a print bed.
Anyway, someone applied glue directly to the glass and printed something and the glass broke either due to print shrinkage or excessive force trying to remove it from the bed, so now I'm replacing the glass with a cast aluminum tooling plate. I'm also converting from a dumb 4-point leveling scheme to a 3-point scheme. I'll probably replace the plastic bushings on the Y axis with ball bushings, too.
April 20, 2016 07:54AM
I will do a very low speed tonight with delay tonight,
I can't find anything in the datasheet about the adaption speed of the sensor, instant ?
April 20, 2016 09:41AM
Mhh found the settling times. by default it would be 0.1 seconds. So I already measure to fast for that.
But the sensors I got are not setup with default values ( one critical one was already different my sensors went to PWM mode automatically, by default it should be I2C ),
so I need to first check the setting tonight.
[cdn-shop.adafruit.com]
The setteling time depends on the IIR and the FIR filters. I have read a little bit about it but I have no clue on what the best is for this.
I expect that I want to have a descent filter that removes spikes, but that gives a big settling time.
April 20, 2016 10:23AM
The biggest single thing that influences the temperature of various points on the bed is how well insulated it is on the top - by what is being printed. A large object covering the center of the panel (and presumably the temperature sensor) will hold the heat in there so that the temperature towards the edge of the piece will be much lower. What would be nice is a multi-zone heater so that each area is independent - I am not sure how that could be done at a reasonable price though.
Mike
April 20, 2016 10:41AM
This temperature sensor is ~1cm above the glass plate, it is a contact less sensor, and I agree with the statement that where the object is printed it can easily hold the temperature. I just want to have the starting
temperature reproducible. That is now because of the position of the bed temperature sensor not possible. The temperature matrix is just a nice to have feature. But t show also how good the measurement is.
Let me say this, I don't trust the measurements that it is doing now :-)
It has to big jumps and high temperatures at the edge. I think I need to check what the settling time is ( directly connected to the IIR and FIR filters ).
April 20, 2016 02:39PM
hahaha, settling time is 4.5sec so all the data is time shifted because of the filter settings full IIR and FIR filters :-)
April 20, 2016 02:41PM
4.5S!? That seems like a very long time for an IR based sensor.
April 20, 2016 03:37PM
it had full IIR and FIR digital filter, I switched of the IIR now, readings still good, settling time is now 0.1 sec
when I reduced the FIR filter, readings where completely wrong -91c
I have now the problem that repetier ignores the delay that I added???
April 20, 2016 03:42PM
and it doesn't ignore them always ???? first line over the Y axes goes now OK, but that is also not always the case
April 21, 2016 02:55AM
What a good night sleep can dospinning smiley sticking its tongue out
I know what is going on. I created a double loop with the moves and the delay and the measurement
The problem is that the moves are queued and the delay and measurements not.. I would expect that a function that queues something would have that made clear in the name of the function.
April 21, 2016 06:44AM
Well that would be confusing for sure smiling smiley
April 21, 2016 02:59PM
and now a good one :-)
complete measurement takes 1 minute, so bed was still heating up
April 21, 2016 03:10PM
and now after 6 minutes
not bad about ~ 10 degrees difference
Now making a gcode implementation for heating bed to what for IR sensor to reach desired temperature
with overruling the set temperature
Edited 1 time(s). Last edit at 04/21/2016 03:13PM by amigob.
April 21, 2016 03:17PM
That looks much more believable smiling smiley The 10 degrees centre to corner difference is about what I remember seeing with my heatbed. Very nice capability you've implemented there. How big is the offset from the sensor to the nozzle? You could imagine using the sensor to monitor the print surface temperature and adjust cooling and speed based on actual temperatures instead of guesswork based on layer time (temperature build-up can be very different depending on the tool path for the same layer time). That would be hugely useful.
April 21, 2016 04:31PM
using it to check temperature of the object while printing is an option.
Until now I only needed that when I printed thin walls and then I don't think it will work.
Just implemented , M703 , call it with a temperature and it will switch the heater to max temperature ( config )
and waits until the bed sensor reaches the requested temperature.
And then sets the temperature to requested bed temperature
video here
Edited 1 time(s). Last edit at 04/21/2016 04:31PM by amigob.
April 25, 2016 08:16AM
so made the first prints with the M703, had some small problems finding the correct way of injecting M703
Add it to the repertier start code, didn't always work ( still don't know why ), it is also not really the correct location because
I need to change printer settings when I change filament type.
Then I moved it to the start code of slic3r, that didn't work because I ended up with 2 blobs of filament on the middle of the build plate.
Because the extruders where starting to heat before the M703 command.
They would probable be pushed of when printing, but I didn't like it.
For now it looks like I will integrate a post processing script that adds the command, but I need to check if I can handle different scrips for different filaments.
Like to have it automated.
BTW, I manually now add the M703 S100 and the bed heating is done within 7 minutes ( top of the bed is then 100c ).
the filament sticks so well that I am going to reduce the temperature for the first layer, and increase it for non first layer layers in the hope that it will stick less :-)
