Friends -
Please see this
belt mounting strategy on a modified Prusa i3 Extruder Carriage.
We are printing the extruder carriage as a 2 piece clamshell. See picture at [
docs.google.com]
Here's the embedded picture:
Design Rationale for Belt Mounting:
1. Removable plug is used to fix belt into place. No clips or zip ties needed
2. One side is fixed first with first plug.
3. Then the second side belt is woven through the hole in the removable plug.
4. Belt is tensioned as needed.
5. Second plug is inserted to fix belt
6. At that point - belt is fixed - it can't slip out, nor can the plugs slip out - because the teeth in the 3D printed Extrude Carriage piece hold the belt firmly
Has anyone else used this strategy? Does it work? Any pictures of examples?
Marcin Jakubowski and Michel Dhoore
Edited 1 time(s). Last edit at 07/30/2016 03:09PM by marcin_ose.
