Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 07, 2016 11:08PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 04:56AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 06:30AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 11:00AM |
Very useful for tuning exactly the correct amount to extrude on a prototype that keeps changing.|
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 11:48AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 12:19PM |
darenschwenke
I can vary the speed from 50% to 300% while printing and for the most part, it's doing the right thing already. Well, I can vary any parameter, while printing...Very useful for tuning exactly the correct amount to extrude on a prototype that keeps changing.
The math for going faster (increasing the look-ahead), requires some ringbuffers to shift the timescale of the motion.
Yeah, you can do that too and others have already. I'm just behind.
Still, if you can sell the head at a reasonable price then it may be popular with Duet WiFi users. With the expansion board it already supports up to 8 extruders, so no additional electronics needed.|
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 12:33PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 12:35PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 01:20PM |
darenschwenke
I'm working on allowing you to use your existing controller... if you are happy with it.
darenschwenke
For development purposes, Machinekit was a lot easier to modify for this.
It can generate 9 channels of 1/32 microstepped step/dir signals and 5 channels of PWM, and has a proper motion planner to do the look-ahead on one board, right out of the box.
darenschwenke
I thought the expansion was a multiplexer... in other words... select a single channel and output. Not output to 6 at the same time.
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 02:12PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 04:25PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 08, 2016 05:08PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 11, 2016 03:01PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 12, 2016 09:40AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 12, 2016 02:07PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 13, 2016 05:27AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 13, 2016 07:38AM |
o_lampe
Actually I like the decent pale colors, much more than the usual kiddy-toy colors.
Do you plan to print a checkered part, like a chess board soon? I'd like to see how machinekit handles sharp color changes in one layer.
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 13, 2016 12:36PM |
Basically, no. You'll always have some volume of filament in the mixing area/nozzle you need to purge to get to the target color.Quote
JamesK
o_lampe
Can any mixing head handle sharp color changes in one layer?
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 13, 2016 07:00PM |
Challenge accepted?Quote
JamesK
o_lampe
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. November 14, 2016 01:56PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. December 01, 2016 08:56PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. December 02, 2016 03:36AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. December 02, 2016 10:20AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. December 02, 2016 11:44AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. December 02, 2016 12:46PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. January 10, 2017 03:27PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. February 28, 2017 02:04PM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. March 01, 2017 02:19AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. March 01, 2017 02:33AM |
Re: Arcus3D M2 - Six material, active mixing linear delta 3d printer. March 09, 2017 07:32AM |
