DuetWiFi Lash-Up January 06, 2017 11:42PM |
Re: DuetWiFi Lash-Up January 07, 2017 03:14AM |
Re: DuetWiFi Lash-Up January 07, 2017 01:15PM |
Re: DuetWiFi Lash-Up January 07, 2017 01:36PM |
Re: DuetWiFi Lash-Up January 07, 2017 03:02PM |
Giark
I did some investigating and you are correct about the HSMCI pins. All of them are available except for MCDA0. Sadly, that pin was used exclusively to blink the TX LED. The LED could be removed and a wire run from it's cathode pad, I suppose; however, the main problem with the mightyboard I want to replace is noise. Gets into everything because of questionable board layout and inadequate decoupling (at least on the Chinese knockoff one that came in my printer). A spaghetti lash-up, now with a critical high speed data line running through a 30 gauge wire soldered to an LED pad, is sounding a bit dubious.
Re: DuetWiFi Lash-Up January 07, 2017 05:14PM |
dc42
If you want to reduce noise from the stepper motors, you can't beat the TMC2660 drivers. Numerous users have posted how quiet their printers have become since upgrading to the Duet WiFi.
Re: DuetWiFi Lash-Up January 07, 2017 06:29PM |
Re: DuetWiFi Lash-Up January 07, 2017 08:03PM |
Re: DuetWiFi Lash-Up January 09, 2017 05:06AM |
Re: DuetWiFi Lash-Up April 04, 2017 09:30AM |
Hubberthus
Since there is no real printer firmware written in FreeRTOS, it is daunting indeed.
Re: DuetWiFi Lash-Up April 04, 2017 01:59PM |
xebbmw
Hubberthus
These are the only references for 3d printer controllers that uses FreeRTOS:
Erik Zalm board based on STM32F4: I did not find any firmware for this, the Git repositories shows only a picture of the board. According to the following thread Erik Zalm board is used for Orca-XXL (commercial printer)
Makebed project: based on LPC1768 with links to Git repositories
