Depending on the firmware you are using, you can try to autoPID the extruder heater.
Or maybe your wires from PSU to controller are to thin and cause voltage drop.
Another issue might be, the FET for the extruder is not fully ON, because the 5V rail is somewhere around 4.5V-4.7V. ( Happens mainly on Arduino Mega with Ramps and graphic LCD )
