Re: ESP32 Printer Board December 28, 2017 01:43PM |
Re: ESP32 Printer Board December 28, 2017 04:57PM |
Re: ESP32 Printer Board December 29, 2017 12:00PM |
Re: ESP32 Printer Board December 29, 2017 02:40PM |
Re: ESP32 Printer Board December 29, 2017 03:06PM |
Re: ESP32 Printer Board December 29, 2017 04:09PM |
Re: ESP32 Printer Board December 29, 2017 09:18PM |
Re: ESP32 Printer Board December 29, 2017 11:53PM |
Re: ESP32 Printer Board December 30, 2017 12:03AM |
Re: ESP32 Printer Board December 30, 2017 12:10AM |
JustAnotherOne
@offtherails2010 could KiCad be an alternative ?
Re: ESP32 Printer Board December 30, 2017 12:23AM |
Re: ESP32 Printer Board December 30, 2017 12:38AM |
Re: ESP32 Printer Board December 30, 2017 12:55AM |
Re: ESP32 Printer Board December 30, 2017 01:53AM |
Re: ESP32 Printer Board December 30, 2017 06:04AM |
Re: ESP32 Printer Board December 30, 2017 07:43AM |
Re: ESP32 Printer Board December 30, 2017 10:15AM |
Re: ESP32 Printer Board December 30, 2017 12:26PM |
newbob
ATSAM4S looks great and is not that expensive - strange that there were no controller boards made even though it's been out for three years and it's 79GPIO should be enough for any kind of printer controller. Compared to ESP32, ATSAM4SA16BA-MU is twice the price, 1/2 less flash and probably 1/4 speed (EDIT: SAM4S 180 DMIPS vs 600 DMIPS ESP32 vs 125 DMIPS SAM3 in Duet.)
newbob
as to IO expanders:
SX1509B - is my favorite , it's also used in Duet WIFI. I2C port expander with hardware PWM and blink functions. Lots of code examples available in C and Arduino.
SX1512B - same as SX1509B but with SPI interface. Not as popular, more expensive and harder to obtain.
MCP23S17 - is great if you are OK with doing PWM in software. Is't unique feature are two interrupts that that can be configured to fire on every state change or when state does not match a register. When using two of them (for 4 interrupts) interrupts could be configured to trigger for endstops when homing for low latency response (avoids pulling registers through SPI interface). Alternatively one interrupt could be used for all endstops but that's not optimal for delta style printers.
Re: ESP32 Printer Board December 30, 2017 02:05PM |
Re: ESP32 Printer Board December 30, 2017 02:25PM |
Re: ESP32 Printer Board December 30, 2017 02:51PM |
Re: ESP32 Printer Board December 30, 2017 03:34PM |
Re: ESP32 Printer Board December 30, 2017 03:48PM |
Re: ESP32 Printer Board December 30, 2017 03:55PM |
offtherails2010
Howdy Guys
Firstlly i love THIS Microcontroller, ATSAM4S !
Also if we would be theorising about using a non 32 bit ESP module, couuld we possibly use an ESP that has a U.FL Pigtail to SMA connection on the board so we can attach a higher gain aerial/antenna ?
offtherails2010
Secondly, i know we are still ironing out viability with checking out what would run and what wouldnt, im asuming we will STILL be usiing the TMC2130 Stepper Drivers ???
Being run via SPI, the ATSAM4S only has 3 SPI lanes, so only 3 stepper motors can be used unless one uses 2 for the Z axis, then throwing another TMC2130 into a Parallel configuration i think should also be included in this board..
That still isnt enough though for this microcontroller, any idea's how we can get this ATSAM4S to work for us
Re: ESP32 Printer Board December 30, 2017 10:53PM |
Re: ESP32 Printer Board December 31, 2017 03:21PM |
Re: ESP32 Printer Board January 02, 2018 05:49AM |
offtherails2010
Quick Question for the MCP23S17 SPI Expander;
in the datasheet it shows that its speed is 10Mhz MAXIMUM, would this become a problem for a 3D Printer being a bottleneck ??
Re: ESP32 Printer Board January 02, 2018 06:34AM |
Re: ESP32 Printer Board January 02, 2018 09:15AM |
Re: ESP32 Printer Board January 02, 2018 09:56AM |
