Correcting horizontal banding in gcode with python October 05, 2017 05:09PM |
Re: Correcting horizontal banding in gcode with python October 06, 2017 02:37AM |
Re: Correcting horizontal banding in gcode with python October 06, 2017 10:37PM |
Re: Correcting horizontal banding in gcode with python October 07, 2017 12:16PM |
Re: Correcting horizontal banding in gcode with python October 08, 2017 07:47PM |
Re: Correcting horizontal banding in gcode with python October 09, 2017 03:41PM |
Re: Correcting horizontal banding in gcode with python December 08, 2017 06:12PM |
Re: Correcting horizontal banding in gcode with python December 29, 2017 03:24PM |
Re: Correcting horizontal banding in gcode with python December 30, 2017 09:55AM |
wersy
It would be interesting to know what the reason really was. You think it was caused because the pulleys are eccentric. Maybe it is possible to proof this with a disc like a clock face and a pointer mounted on the lead screw. In similar way we tested the clocking of stepper motors.
Re: Correcting horizontal banding in gcode with python December 30, 2017 10:33AM |
Re: Correcting horizontal banding in gcode with python December 30, 2017 12:53PM |
Re: Correcting horizontal banding in gcode with python December 30, 2017 03:53PM |
Re: Correcting horizontal banding in gcode with python December 31, 2017 04:16PM |
newbob
There's one other situation I can think of that could cause this: in four screw arrangement, periodically, one screw could take over from the other (due to backlash between nut and screw bed would not lock out) making vertical movement uneven.
Re: Correcting horizontal banding in gcode with python December 31, 2017 06:32PM |
Re: Correcting horizontal banding in gcode with python January 02, 2018 11:25AM |
Re: Correcting horizontal banding in gcode with python January 03, 2018 11:18AM |
the_digital_dentist
2 rails should provide the necessary lateral and rotational constraint.
justine.haupt
I'm confident that my four-screw bed is more stable and precise than a 3-screw version of the same bed would be.
justine.haupt
Aligning four leadscrews and four linear shafts is tricky and important, but by no means a show stopper.
justine.haupt
In fact, I wonder if an imperceptible amount of buckling due to the weight of the HBP (even with 16mm diameter screws) was part of the problem.
Re: Correcting horizontal banding in gcode with python January 03, 2018 01:34PM |
Re: Correcting horizontal banding in gcode with python January 04, 2018 03:24AM |
the_digital_dentist
It seems to me that if the bed support structure is unstable on 4 screws, even if (or especially if?) it can flex (a second form of instability), then the bed that sits on those 4 screws is equally unstable, 3 leveling screws or not. But if it works, it works.
Re: Correcting horizontal banding in gcode with python January 08, 2018 02:07PM |
wersy
Are you quite sure that you first had all aligned with equal care as now incl. levelling of HBP?
I am sure you didn't use bearings on top for the lead screws.
wersy
I have never seen such a solid printer than yours! This is a real professionally build machine, and it is so big that it possibly could print my big wing in 2 parts instead in 40 parts smiling smiley
[www.youtube.com]
