Core XZ kinematics like in 3DP troubles
Posted by rarprint
November 05, 2017 02:07AM
Hello!
I try to make kinematics like in 3dp fdm 3d printer only with belt. In original they use screws:
I made drawing with reference to original coreXY kinematics, tell me where I made mistake?
There is only X axis where extruder moving and Z axis where all vertical portal move up and down. Could be this reproduce with coreXY kinematics?
Re: Core XZ kinematics like in 3DP troubles
November 06, 2017 04:18AM
Z cant work like that
Although z can be manually moved up and down. this doesnt result in rotation of the steppers. And the reverse is also true, with X fixed you cant rotate the steppers.
November 06, 2017 06:48AM
I suggest you search this forum for "CoreXZ". There is at least one thread on this subject.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
November 07, 2017 01:38AM
dc42
Thank u dc42! I found answers in this topic [forums.reprap.org]
