Recommendations for large format heatbed
Posted by obelisk79
November 11, 2017 11:20PM
I'm in the build stage of a large format corexy printer, the print bed will be approximately 475mm x 475mm. How should I handle heating the bed. The commonly available options of silicone pad and/or pcb style don't seem to come in a large enough format.
Re: Recommendations for large format heatbed
November 12, 2017 01:15AM
You'll probably have to order a custom silicone heater, and pay accordingly. If the printer is going to be printing ABS and you don't want to wait too long for it to heat up to print temperature, you'll want about 0.5W/cm^2- i.e. about 1kW. Don't even think about using DC power- this calls for AC line power. You'll want to add a thermal cutoff and fuse to protect against SSR/controller failure and wiring problems.
My 300x300x8 mm cast aluminum bed has a 750W heater and gets to 105C to print ABS in about 4.5 minutes.
Son of MegaMax 3D printer: [www.instructables.com]
November 12, 2017 02:27AM
For a really large bed it'd make sense to use individual heaters. You could ask for two 500x250-ish or four ( more common ) 200x200 silicone heaters. Then you can print smaller parts without adding too much "global warming"
November 12, 2017 02:39AM
Also ,you can try my decision for large heat bed. (450x600mm)
[forums.reprap.org]
Edited 1 time(s). Last edit at 11/12/2017 02:39AM by rarprint.
December 08, 2017 06:05PM
If you really don't want to go custom you might also consider a mosaic of 4 square silicone heaters. Perhaps you could find 9x9", I don't know.
This is the route I went for a 610mm square bed using four 12"x12" pads. I'd originally planned on an off-board closed-loop controller for each zone, but the pads are consistent enough that I've been running all four off one thermistor using the stock heater output (Duet Wifi fed to relays) without undue temperature variation. Separate controllers is a possible future upgrade but I haven't figure out a way to feed the bed set point from the Duet.
~Justine
Edited 1 time(s). Last edit at 12/08/2017 06:05PM by justine.haupt.
December 09, 2017 02:31AM
justine.haupt
The 1.20RC1 firmware for the Duet WiFi/Ethernet that I released yesterday supports multiple independently-regulated bed heaters.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet [www.duet3d.com].
December 11, 2017 01:34PM
dc42
Wow great news! Thanks for the update!
December 11, 2017 05:29PM
justine.haupt
dc42
I slightly jumped the gun, because although the support is there, in the RC1 build there is a limit of 1 bed and 2 chamber heaters. I'll increase it to 4 bed heaters in RC2 which I expect to release later this week.
January 02, 2018 11:49AM
FYI,
dc42 made said update. Happy multi-zone bed user here.
Edited 1 time(s). Last edit at 01/02/2018 11:51AM by justine.haupt.
