Analog output proximity sensor
Posted by leadinglights
January 24, 2018 05:02AM
Question: Are there any proximity sensors that give an analog output?
I do know that DC42s IR sensor has an analog output and that if you are willing to pay over £200 there are several inductive ones but nothing else jumps out from eBay, amazon or even Alibaba that fits the bill. Can an inductive probe be canabalized to get at a part of the circuitry that would do it?
The question is because I am playing with an idea that has nagged at me since doing a little research on bed leveling sensors. Sensors are mostly either nozzle contact e.g., Piezo, FSR, Strain Gauge etc., or they are proximity senors, inductive, capacitive, optical etc.. The one exception that I have found is the latest Ultimaker 3 which uses the nozzle itself as a capacitative proximity sensor: As the nozzle gets closer to the bed the capacitance increases until it touches the bed and can't increase any more - I have adopted and annotated a diagram from Daid on [community.ultimaker.com] which explains this.
My thought is that any sensor which is able to give an output at least roughly proportional to distance could become that basis of a really good leveling technology. The main requirements are a reasonable resolution, a fairly short latency (time between the sensor reaching a height and the microcontroller getting this data) and a halfway reasonable short term stability.
The sequence is this:
1. The nozzle is moved to say 5mm above the bed then moves slowly towards the bed while the analog output from the sensor is measured.
2. When the nozzle contacts the bed the capacitance stops going up and the nozzle retracts a known distance.
The important point here is that the distance is known from how far the stepper or serve needed to be driven so long term stability is not a major issue.
3. The last stage is that the sensor can now scan the whole of the print bed at any desired resolution and at high speed - without pogoing at each point.
Absolute linearity is also not a big problem as this can be mapped in much the same way as a thermistor table can be used to linearize its response.
Any thoughts? Is this a project that may be worth investigating?
Mike
Re: Analog output proximity sensor
January 24, 2018 06:03AM
A few years ago I built a capacitive sensor that gave an analog output, and I started building an inductive one that did too. But I abandoned them when I discovered differential IR.
I've never taken a commercial inductive sensor apart, so I don't know whether they use analog electronics or microcontrollers these days.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
January 24, 2018 08:08AM
ESP32 and probably most other new SoC have capacitive touch peripherals that measure capacitance.
I also seen astable multivibrator examples that use capacitance to change oscillation frequency that can be sampled with uC:
Edited 1 time(s). Last edit at 01/24/2018 08:18AM by newbob.
January 24, 2018 09:08AM
That might even be the way to go as even Microchip PIC16s are available with CapSense. Inductive may also be good or possibly ultrasonic like AlignG [aligng.com] which has an analog output but won't tell anybody the price.
At the moment DC42s IR sensor looks a good place to begin but I won't be able to try anything out much before summer.
Mike
January 24, 2018 11:04AM
The thread you've referenced lists TI chip that U3 is using. At $6 a piece that does not seem too expensive. Dedicated sensor like that likely has better range and accuracy compared to uC capacitive touch feature.
Edited 2 time(s). Last edit at 01/24/2018 01:38PM by newbob.
January 24, 2018 03:13PM
You don't need anything complicated to do capacitive sensing. My prototype capacitive height sensor used a <$1 attiny microcontroller and a few external resistors and capacitors. I still have the code if anyone wants it. However, capacitive sensors are sensitive to humidity and temperature as well as bed surface, so they are probably the least accurate type of height sensor to use.
January 25, 2018 02:18AM
I've got two 18mm capacitve sensors, which also have sort_of_analog output. I didn't digg deeper into that subject. They send out a frequency that changes with distance. Also changes PWM duty cycle.
IDK if mesh probing in Pogo style is such a bad idea. Because it offers a visual way for me to see when it has triggered.
I only do it once after I changed anything in the printer hardware, then use G29 S1.
Ebay.de link
January 25, 2018 10:19AM
@o_lampe
Can you tell us what the make and model of that capacitave sensor is?
There is nothing wrong with pogo mesh probing but if the datum height has been established by one dive to nozzle contact then it is no longer necessary and mesh scanning can take place at speed. As with any printer, if it is solid then it needs only a sanity check, one or three point, to see that nothing has gone wrong - like a bit of ABS under the removable bilid stage.
Mike.
January 26, 2018 03:05AM
@o_lampe
I gave you the link to a german vendor, but his part number is the same as any other: LJC18A3-8-Z/BX. Maybe you can search for the phrase "dual mode", too?
The sticker is in chinese and there is the brand name? ZHNQI on it.
VDX
January 26, 2018 04:31AM
... some years ago I've built a 3D probe, where the sensor body was floating in ferrofluid and "fixed" by magnets.
There were 6 caps (pairs for X, Y and Z) as sensors around the body to detect the displacement of it in all directions. As the caps were placed inside the ferrofluid, they weren't sensitive to surrounding air or humidity winking smiley
Viktor
