RuRAMPS4D new Board for 3D printer and arduino due
Posted by svs072477
July 22, 2018 09:32AM
A new Board for 3D printer and arduino due from Russia.
http://ruramps4d.ru
The Board is already on sale and is shipped worldwide. Delivery is already included in the price.
Key board features:
  • Possibility to use TMC2130 in SPI mode without wires. The SPI bus is already connected to the drivers on the PCB.
  • 12-26V DC power supply;
  • Number of installed drivers for form factor Pololu — 6;
  • The total number of outputs for connection to the load via the MOSFET — 7;
  • Outputs for connection of hotends— 3;
  • Low-power outputs for connection of controlled fans – 2;
  • Outputs for connection of Heated Bed or Chamber heater (powerful IRL1404 installed). When connecting 2 MK2b tables to one channel — cold) – you can connect large tables, two-zone table from Cheap3D, or several simultaneously;
  • Inputs for connection of thermistors – 5;
  • Outputs for servo connection – 2;
  • Possibility to connect external 5V power supply for servos;
  • A connector for connecting the wifi module ESP8266-01;
  • Ability to connect external 3.3 V power for WiFi module ESP8266;
  • EEPROM chip;
  • The displays the RepRap Discount Controller series connect to board without the adapter;
  • Separate connector for MKS TFT and Nextion displays;
  • Optional amplifiers for connection of 2 K-type thermocouples are installed.
Re: RuRAMPS4D new Board for 3D printer and arduino due
July 23, 2018 01:22AM
Sounds like a new version of RADDS.
Which firmware does it work with?
July 23, 2018 04:41AM
Marlin 2.0
Mk4DUO
Repetier
o_lampe
July 23, 2018 03:44PM
open source?
July 24, 2018 03:01AM
I am now studying the options for open source licenses and how to get them. When I'm done, I'll publish the documentation
boelle
open source?
July 24, 2018 03:33AM
I use Cern OHL 1.2 [www.ohwr.org] for my Merlin Hotend. It is one of the few realy hardware oriented open source licenses.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
September 26, 2018 12:56PM
Will you be providing all of the documentation including the original design files so that someone can build one of these boards themselves? Meaning if I wanted to I could order unpopulated PCBs and the individual components and populated the board myself? You can do this with an Open Source license that prevents commercial use.
September 27, 2018 06:51AM
There are plans for this, but I can not yet understand what license is better to use. In addition, it is unlikely to protect against Chinese copies
CthulhuLabs
September 27, 2018 09:46AM
Nothing will protect you from chinese copies. However, unless your board gets very popular, they are unlikely to clone this.
December 02, 2018 02:15PM
Is there ducumentation in English?
May 07, 2019 04:58AM
Has anyone bought one of these? If so how do they perform?
