FDM 3D printer with UV Resin?
Posted by boylucky
December 15, 2018 01:11PM
Hi all,
probably stupid idea but why not to ask spinning smiley sticking its tongue out. Do you think that it would be possible to make clasic FDM printer which would use UV resin flowing from the head with UV diod instead of PLA and other filaments? I mean if there would be possible to change the normal hotend for something where the UV rasin would slowly flow out and would be imediately solidify by UV light (some small cheap UV diod if suitable). Like I said, it is probably stupid crazy idea spinning smiley sticking its tongue out. I have only experiences with couple of normal cartesian and delta printers and no experiences with UV resin printers. But I just thought to make something what would be combination of both. Sorry in advance for such stupidity spinning smiley sticking its tongue out and thanks for your comments.
VDX
Re: FDM 3D printer with UV Resin?
December 15, 2018 01:26PM
... look here - [reprap.org]
Viktor
VDX
December 15, 2018 01:29PM
... here is the related (10 years old) thread - [reprap.org]
But actually I'm mostly using a piezo-valve-dispenser for UV curable resins - [reprap.org]
Edited 1 time(s). Last edit at 12/15/2018 01:31PM by VDX.
Viktor
December 15, 2018 01:36PM
Thanks VDX for your posts. Looks good. I also tried my own solution for 3D printing with soil. Here you can see some test printing video here
But the question is if the UV resin could be used for it and if some cheap diods would be fast enough to make it solid when out of the nozle and if it would make a sense.
Edited 1 time(s). Last edit at 12/15/2018 01:37PM by boylucky.
December 15, 2018 02:04PM
Ok, now I see also that they mentione the UV resin there but do not see any pictures with the result if he succeed sad smiley
VDX
December 15, 2018 02:56PM
... with the piezo-valve-dispensers it's like "shooting" droplets on the surface, what's pretty much mechanical energy, so can distort thinwalled structures.
With a piston dispenser this would be better in terms of dimensional stability.
Curing is best done with 405nm-diodes - there are some available with optical output powers of up to 3 Watts ... I've used 3Watts for printing (but my watercooled diodes can emit up to 9Watts)
Here and attached some images from "prints" with the piezo type:
And some videos:
[vimeo.com]
[vimeo.com]
[vimeo.com]
Viktor
open | download - 07_800x400.png (280.3 KB)
open | download - 3c_800x400.png (286.2 KB)
December 16, 2018 02:16AM
Would it be OK to use normal UV-LEDs instead of Laser-diodes?
VDX
December 16, 2018 03:32AM
... my 9Watt-UV-emitters are LED's, not laserdiodes:
And yes, normal 1W- or 3W-LED's are sufficient too - you can combine more of them to get higher powers:
Viktor
February 06, 2022 12:10PM
Sorry to resurrect an old thread, but I was thinking about making this type of printer. I can only find a couple of examples of people considering it.
I see that with your piezo valve dispenser, you were able to solidify drops. What resolution were you able to accomplish? How quickly were you able to cure the resin with the 4 led setup you shared a picture of?
Thank you!
VDX
February 06, 2022 03:33PM
... the smallest droplet size depends on viscosity and "content" of the paste - the blue glue was around 0,07mm smallest, other pastes could be like 0,04mm.
The curing time depends on droplet size too, activators/inhibiters and additives - some 10 milliseconds per droplet, but I'm either dispensing/curing continuous with the nozzle-design, or (with the piezo-jetter) printing the complete slice, then curing it competely too by moving the UV-LED's in meandering paths to cure every bit.
Viktor
