T-Bot: drawing diagonal lines
December 18, 2018 05:11PM
I’ve made a T-Bot similar to this design. Using stepper motor driver L6470, I can control the movements e.g. up/down, left/right and diagonally using the equations shown here corexy, via the L6470 command MOVE(direction, number_of_steps) using MAX_SPEED(100 step/s).
If I move from (0, 0) to (400, 400), both stepper motors move at a constant speed, and reaches (400, 400). Great.
If I move from (0, 0) to (400, 100), then I need to reduce the speed of one of the stepper motors by 4 times (400 / 100 = 25 step/s). Fine.
However, if I move from (0, 0) to (400, 300), I reduce the speed of one of the stepper motors by 1.3 times (400 / 300 = 1.333 step/s). Slight issue here, MAX_SPEED only accepts integers and therefore the linear path it follows is not correct – one stepper motor will stop before the other, and a diagonal line is not drawn correctly.
Is there a way of resolving this issue?
Sample Python code looks like this,
# Maximum speed
STEP_PER_SECOND = 100
def doLine(dX, dY):
    # Coords
    dX = 400
    dY = 300
    # Coordinates to motor absolute position
    dY = -dY
    a_pos = dX + dY
    b_pos = dX - dY
    print("A_POS:", a_pos, "B_POS:", b_pos)
    a_pos_temp = abs(a_pos)
    b_pos_temp = abs(b_pos)
    a_spd = STEP_PER_SECOND
    b_spd = STEP_PER_SECOND
    if (a_pos_temp > b_pos_temp):
        b_spd = round(abs(STEP_PER_SECOND * (b_pos_temp / a_pos_temp)))
    elif (a_pos_temp < b_pos_temp):
        a_spd = round(abs(STEP_PER_SECOND * (a_pos_temp / b_pos_temp)))
    print("A_SPD:", a_spd, "B_SPD:", b_spd)
    MOTOR[0].setMaxSpeed(SE.steps_to_maxspeed(a_spd))
    MOTOR[1].setMaxSpeed(SE.steps_to_maxspeed(b_spd))
    # Move stepper MOTOR
    if (a_pos < 0):
        MOTOR[0].Move(SE.REV, -a_pos)
    else:
        MOTOR[0].Move(SE.FWD, a_pos)
    if (b_pos < 0):
        MOTOR[1].Move(SE.REV, -b_pos)
    else:
        MOTOR[1].Move(SE.FWD, b_pos)
    while (GPIO.input(SE.MTR0_BUSY) != 1) or (GPIO.input(SE.MTR3_BUSY) != 1):
        pass
Edited 2 time(s). Last edit at 12/18/2018 05:44PM by rraghvani.
Re: T-Bot: drawing diagonal lines
December 18, 2018 11:20PM
Integer math is funny, isn't it? Don't know, if I can explain...
Usually you multiply the floating value by right shifting ( eg. >>8 ),
then forget about the fractions and do the operation in integer.
Later you left shift (<<8 ) the result to get your final value.
Maybe you can read more qualified explanation about Integer math in the net.
December 29, 2018 06:05AM
Update,
As I was unable to use the methods provided by the L6470 chip, to do what I wanted. I have now used Step Clock mode instead. I have written methods which allows me to rotate the stepper motors a step (i.e. 1.8 degrees); using Bresenham’s line algorithm to draw diagonal lines without having to decrease or increase speeds.
Here’s a little video, which follows some basic coordinates.
December 30, 2018 02:45AM
I just read my own comment and noticed it's the opposite way around: left shift doubles the value, right shift halfes it. eye rolling smiley
