TeensyPrinter: a RAMPS-like board built around the Teensy 3.6 March 25, 2019 03:48PM |
Re: TeensyPrinter: a RAMPS-like board built around the Teensy 3.6 March 26, 2019 01:16PM |
Re: TeensyPrinter: a RAMPS-like board built around the Teensy 3.6 March 26, 2019 10:26PM |
orbitalair
How is this coming?
Could you spin a simpler version with just the basics? I have some teensy 3.1s I think.
Can KiCAD export a eagle fileset?
Also if the board is 100mmx100mm or less several asian companies will spin 10 boards for $2 or $5.
Re: TeensyPrinter: a RAMPS-like board built around the Teensy 3.6 March 27, 2019 09:46AM |
Re: TeensyPrinter: a RAMPS-like board built around the Teensy 3.6 March 27, 2019 06:46PM |
salfter
Is there enough I/O on a Teensy 3.1 to drive even a single-extruder configuration? Each extruder needs three digital outputs (step, direction, chip select), a PWM output (heater), and an analog input (thermistor). Axis steppers need three digital outputs each.
It needs 2-oz. copper to get heavy enough traces to handle up to 15A in some places
Re: TeensyPrinter: a RAMPS-like board built around the Teensy 3.6 March 27, 2019 07:15PM |
frankvdh
salfter
Do you really need a Chip Select on every stepper? So long as you aren't actually sending step pulses, nothing will move. Maybe you can tie CS to be true all the time?
Also, for mixing extruders like the Diamond, you only need one heater and thermistor for 3 or 5 steppers.
I suggest not directly powering the bed heater from the controller.
For a printer with more modest needs (like an Anet A8 or some other smallish printer with a 100-120W DC heater), the onboard MOSFET is an option. Put 24V through it and you can get twice the power at the same current (or the same power at half the current).|
Re: TPS: a RAMPS-like board built around the Teensy 3.6 March 27, 2019 11:46PM |
Re: TPS: a RAMPS-like board built around the Teensy 3.6 March 28, 2019 03:58AM |
salfter
You can't configure TMC2130s without it. Each SPI slave needs its own CS line.
Re: TPS: a RAMPS-like board built around the Teensy 3.6 March 28, 2019 12:35PM |
dc42
salfter
You can use a common CS for all the stepper drivers if you daisy chain the SPI signals. This means that you have to write to/read from all the drivers in every transaction.
Re: TPS: a RAMPS-like board built around the Teensy 3.6 March 28, 2019 03:36PM |
Re: TPS: a RAMPS-like board built around the Teensy 3.6 March 28, 2019 05:29PM |
Re: TPS: a RAMPS-like board built around the Teensy 3.6 June 12, 2019 02:19PM |
