X Y axis accuracy doubled. May 27, 2011 03:26PM |
Re: X Y axis accuracy doubled. May 27, 2011 03:59PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: X Y axis accuracy doubled. May 27, 2011 04:21PM |
Re: X Y axis accuracy doubled. May 31, 2011 12:15AM |
Re: X Y axis accuracy doubled. May 31, 2011 01:08PM |
Re: X Y axis accuracy doubled. May 31, 2011 04:16PM |
Re: X Y axis accuracy doubled. May 31, 2011 08:21PM |
Re: X Y axis accuracy doubled. June 01, 2011 01:00AM |
Re: X Y axis accuracy doubled. June 01, 2011 06:50AM |
Re: X Y axis accuracy doubled. June 16, 2011 03:27AM |
Re: X Y axis accuracy doubled. June 16, 2011 05:31PM |
Re: X Y axis accuracy doubled. June 30, 2011 02:05PM |
Re: X Y axis accuracy doubled. June 30, 2011 07:37PM |
Re: X Y axis accuracy doubled. June 30, 2011 08:15PM |
Re: X Y axis accuracy doubled. July 01, 2011 01:28AM |
brnrd
I also thought that the having the belt turn with the teeth facing outside leads to belt failure according to Nophead.
Re: X Y axis accuracy doubled. July 01, 2011 03:18AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: X Y axis accuracy doubled. July 01, 2011 12:47PM |
Re: X Y axis accuracy doubled. July 01, 2011 01:05PM |
Re: X Y axis accuracy doubled. July 01, 2011 01:26PM |
Re: X Y axis accuracy doubled. July 04, 2011 03:34PM |
Re: X Y axis accuracy doubled. August 09, 2011 07:31PM |
____________ / ___ ___ \ | \ / | \____/ \____/
Re: X Y axis accuracy doubled. August 10, 2011 05:00PM |
Re: X Y axis accuracy doubled. August 11, 2011 01:12AM |
Re: X Y axis accuracy doubled. August 11, 2011 04:23AM |
Re: X Y axis accuracy doubled. August 11, 2011 10:47AM |
Re: X Y axis accuracy doubled. August 12, 2011 12:47AM |
MadKite
I ended up putting the Kevlar belt on the Y axis. But the X axis is still running the same old steel cored belt and bending it both ways with no problem! The Kevlar is better though being more flexible so going round smaller pulleys is possible. But I don't know why it is fine on the X but not on the Y.
Re: X Y axis accuracy doubled. August 12, 2011 03:08AM |
Re: X Y axis accuracy doubled. August 12, 2011 03:24AM |
You selected: Width: 5 Length: 6 Type: Not Required Tension: Kevlar Material: Standard 590 White PU Total: £18.42 ex VAT
Re: X Y axis accuracy doubled. August 13, 2011 07:51AM |
Re: X Y axis accuracy doubled. September 09, 2011 07:29PM |
