220V extruder ?
Posted by CJ.BRAVO
220V extruder ?
July 28, 2019 06:37AM
Hey there,
Running an upgraded printer with a DUET3d 2 wifi board.
I've got a customized extruder (not a typical heating block) which needs non-cartridge heating elements.
The suitable elements run on 220v.
Can I connect them to the board the same way I would connect a 220v bed heater?
Using a SSR and connecting to the E0/1 heaters ?
Thanks
Re: 220V extruder ?
July 28, 2019 07:00AM
You can connect them the same way as you would connect a 220v heated bed, through an SSR and using the E0/1 to switch it smiling smiley
http://www.marinusdebeer.nl/
Re: 220V extruder ?
July 28, 2019 07:15AM
Ok,
So I got it connected. Should I run the standard M303 and read the ADC ?
I ran it and it gave me almost the same readings when using a 12v heating element.
Re: 220V extruder ?
July 28, 2019 11:12AM
CJ.BRAVO
Ok,
Good question, I don't know how much it should differ from each other. You would expect the hotend to heat up way faster, maybe overshoot a lot since a hotend is tiny.
