My 6 input (5+1) mixing hot end February 24, 2020 04:52PM |
Re: My 6 input (5+1) mixing hot end February 24, 2020 05:38PM |
I don’t have a thermal imaging camera and my pension won’t stretch enough for me to buy one, so I’m trying to beg, borrow, or steal one.
Re: My 6 input (5+1) mixing hot end February 25, 2020 04:38AM |
frankvdh
You can buy NoIR cameras for the Raspberry Pi... basically an ordinary camera without the IR filter. I don't know how good they are at thermal imaging, but maybe worth a try? Maybe someone else here knows?
Some random thoughts...
- I wonder about water-cooling... you could move all the heat-breaks closer together and get more uniform heating/cooling effects.
- Why not put all the filament feeds in a circle, which would mean that they're all essentially the same (same angle, same distance), and closer together? But then you're getting towards the Diamond design.
- If your 30W heater isn't good enough, (or even if it is) try insulating the outside of the heater block.
- Tap some helical threads into the holes in your labyrinth to improve colour mixing.
- If there is some significant amount of filament in your labyrinth, it not only impacts the amount of purging at colour changes, but also how far the colour changes need to be ahead of the nozzle position.
- Wish I was a pensioner with a milling machine so I could play with ideas like this.
Re: My 6 input (5+1) mixing hot end February 25, 2020 08:34AM |
Re: My 6 input (5+1) mixing hot end February 25, 2020 12:42PM |
deckingman
[Water cooling - I'd need to fit jackets around the heat sinks so I doubt very much if I could get them much closer. Besides, there is only about 3mm clearance between the hexagonal part of the heat sinks so I can't them much closer.
Re: My 6 input (5+1) mixing hot end February 25, 2020 01:04PM |
Re: My 6 input (5+1) mixing hot end February 28, 2020 05:40AM |
Re: My 6 input (5+1) mixing hot end March 09, 2020 06:19PM |
Re: My 6 input (5+1) mixing hot end March 10, 2020 07:43AM |
Re: My 6 input (5+1) mixing hot end March 12, 2020 04:29PM |
leadinglights
Thank you deckingman, your blog is always an interesting read with both data and discussion. I will continue to watch with interest and it may spur me into starting a blog myself on my humble efforts.
Mike.
Re: My 6 input (5+1) mixing hot end October 29, 2020 06:24AM |
Re: My 6 input (5+1) mixing hot end October 29, 2020 08:05AM |
Re: My 6 input (5+1) mixing hot end October 29, 2020 08:59AM |
Re: My 6 input (5+1) mixing hot end October 29, 2020 08:27PM |
Re: My 6 input (5+1) mixing hot end November 19, 2020 11:51AM |
Re: My 6 input (5+1) mixing hot end November 20, 2020 05:02AM |
Re: My 6 input (5+1) mixing hot end November 20, 2020 09:26PM |
Re: My 6 input (5+1) mixing hot end November 21, 2020 10:18AM |
Re: My 6 input (5+1) mixing hot end November 22, 2020 04:29AM |
Re: My 6 input (5+1) mixing hot end November 22, 2020 04:46AM |
leadinglights
The arrangement used by deckingman is very similar to that used in cylinder blocks of i.c. engines - where the cooling is much more demanding.
Re: My 6 input (5+1) mixing hot end November 23, 2020 12:11AM |
Re: My 6 input (5+1) mixing hot end November 24, 2020 03:46AM |
Re: My 6 input (5+1) mixing hot end November 24, 2020 04:01PM |
Re: My 6 input (5+1) mixing hot end November 24, 2020 05:25PM |
Re: My 6 input (5+1) mixing hot end November 28, 2020 05:37AM |
Re: My 6 input (5+1) mixing hot end June 01, 2021 04:39AM |
