X axis of vibration at low speed October 30, 2020 03:13PM |
Connecting... Printer is now online. >>> M122 S1 SENDING:M122 S1 axis:pwm_scale/curr_scale/mech_load|flags|warncount X Y Z E Address 0 0 0 0 Enabled true true true false Set current 1500 1400 800 500 RMS current 1491 1381 795 489 MAX current 2102 1947 1121 689 Run current 26/31 24/31 25/31 15/31 Hold current 13/31 12/31 12/31 7/31 CS actual 13/31 12/31 12/31 7/31 PWM scale vsense 0=.325 0=.325 1=.18 1=.18 stealthChop true true true true msteps 32 32 32 32 tstep max max max max PWM thresh. [mm/s] OT prewarn false false false false triggered OTP false false false false pwm scale sum 22 21 107 9 pwm scale auto 0 0 4 0 pwm offset auto 52 52 255 36 pwm grad auto 28 25 14 14 off time 4 4 4 4 blank time 24 24 24 24 hysteresis -end 2 2 2 2 -start 1 1 1 1 Stallguard thrs 0 0 0 0 uStep count 332 668 324 148 DRVSTATUS X Y Z E sg_result 152 312 32 0 stst olb ola s2gb s2ga otpw ot 157C 150C 143C 120C s2vsa s2vsb Driver registers: X 0xC0:0D:00:00 Y 0xC0:0C:00:00 Z 0xC0:0C:00:00 E 0xC0:07:00:00 Testing X connection... OK Testing Y connection... OK Testing Z connection... OK Testing E connection... OK X:22/13/-|TI| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:22/13/-|TI| Y:21/12/-|TI| Z:108/12/-|TI| E:9/7/-|TI| X:22/13/-|TI| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:22/13/-|TI| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:22/13/-|TI| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:240/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:108/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:109/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:108/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:172/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:244/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:108/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:44/26/-|TI| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:108/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:108/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:110/26/-|T| Y:21/12/-|TI| Z:109/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:73/26/-|T| Y:21/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:43/26/-|TI| Y:21/12/-|TI| Z:108/12/-|TI| E:9/7/-|TI| >>> M122 S0 SENDING:M122 S0 X Y Z E Address 0 0 0 0 Enabled true true true false Set current 1500 1400 800 500 RMS current 1491 1381 795 489 MAX current 2102 1947 1121 689 Run current 26/31 24/31 25/31 15/31 Hold current 13/31 12/31 12/31 7/31 CS actual 26/31 12/31 12/31 7/31 PWM scale vsense 0=.325 0=.325 1=.18 1=.18 stealthChop true true true true msteps 32 32 32 32 tstep max max max max PWM thresh. [mm/s] OT prewarn false false false false triggered OTP false false false false pwm scale sum 43 21 106 9 pwm scale auto 0 0 4 0 pwm offset auto 52 52 255 36 pwm grad auto 22 25 14 14 off time 4 4 4 4 blank time 24 24 24 24 hysteresis -end 2 2 2 2 -start 1 1 1 1 Stallguard thrs 0 0 0 0 uStep count 332 668 324 148 DRVSTATUS X Y Z E sg_result 92 312 32 0 stst olb ola s2gb s2ga otpw ot 157C 150C 143C 120C s2vsa s2vsb Driver registers: X 0xC0:1A:00:00 Y 0xC0:0C:00:00 Z 0xC0:0C:00:00 E 0xC0:07:00:00 Testing X connection... OK Testing Y connection... OK Testing Z connection... OK Testing E connection... OK
Connecting... Printer is now online. echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing >>> M122 S1 SENDING:M122 S1 echo:busy: processing axis:pwm_scale/curr_scale/mech_load|flags|warncount X Y Z E Address 0 0 0 0 Enabled true true true false Set current 1500 1400 800 500 RMS current 1491 1381 795 489 MAX current 2102 1947 1121 689 Run current 26/31 24/31 25/31 15/31 Hold current 13/31 12/31 12/31 7/31 CS actual 15/31 18/31 25/31 7/31 PWM scale vsense 0=.325 0=.325 1=.18 1=.18 stealthChop true true true true msteps 32 32 32 32 tstep max max max max PWM thresh. [mm/s] OT prewarn false false false false triggered OTP false false false false pwm scale sum 25 28 197 9 pwm scale auto 0 0 0 0 pwm offset auto 54 50 244 36 pwm grad auto 28 26 14 14 off time 4 4 4 4 blank time 24 24 24 24 hysteresis -end 2 2 2 2 -start 1 1 1 1 Stallguard thrs 0 0 0 0 uStep count 356 516 284 148 DRVSTATUS X Y Z E sg_result 200 8 32 0 stst olb ola s2gb s2ga otpw ot 157C 150C 143C 120C s2vsa s2vsb Driver registers: X 0xC0:0D:00:00 Y 0xC0:0D:00:00 Z 0xC0:19:00:00 E 0xC0:07:00:00 Testing X connection... OK Testing Y connection... OK Testing Z connection... OK Testing E connection... OK X:23/13/-|TI| Y:21/13/-|TI| Z:199/25/-|TI| E:9/7/-|TI| X:23/13/-|TI| Y:20/12/-|TI| Z:201/25/-|TI| E:9/7/-|TI| X:23/13/-|TI| Y:20/12/-|TI| Z:201/25/-|TI| E:9/7/-|TI| X:96/26/-|T| Y:20/12/-|TI| Z:202/25/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:196/24/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:174/21/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:158/19/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:143/17/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:121/14/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:104/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:247/26/-|T| Y:20/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:151/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:146/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:107/12/-|TI| E:9/7/-|TI| X:255/26/-|T| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:57/26/-|T| Y:20/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:42/26/-|TI| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X:42/26/-|TI| Y:20/12/-|TI| Z:105/12/-|TI| E:9/7/-|TI| X:43/26/-|TI| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| >>> M122 S0 SENDING:M122 S0 X:43/26/-|TI| Y:20/12/-|TI| Z:106/12/-|TI| E:9/7/-|TI| X Y Z E Address 0 0 0 0 Enabled true true true false Set current 1500 1400 800 500 RMS current 1491 1381 795 489 MAX current 2102 1947 1121 689 Run current 26/31 24/31 25/31 15/31 Hold current 13/31 12/31 12/31 7/31 CS actual 26/31 12/31 12/31 7/31 PWM scale vsense 0=.325 0=.325 1=.18 1=.18 stealthChop true true true true msteps 32 32 32 32 tstep max max max max PWM thresh. [mm/s] OT prewarn false false false false triggered OTP false false false false pwm scale sum 44 20 106 9 pwm scale auto 0 0 6 0 pwm offset auto 49 50 249 36 pwm grad auto 21 26 14 14 off time 4 4 4 4 blank time 24 24 24 24 hysteresis -end 2 2 2 2 -start 1 1 1 1 Stallguard thrs 0 0 0 0 uStep count 356 516 284 148 DRVSTATUS X Y Z E sg_result 104 8 32 0 stst olb ola s2gb s2ga otpw ot 157C 150C 143C 120C s2vsa s2vsb Driver registers: X 0xC0:19:00:00 Y 0xC0:0C:00:00 Z 0xC0:0C:00:00 E 0xC0:07:00:00 Testing X connection... OK Testing Y connection... OK Testing Z connection... OK Testing E connection... OK
Re: X axis of vibration at low speed November 02, 2020 04:20PM |
