Thanks @Dust. Ok, I got around it by disabling watchdog but I will re-enable with that setting.
What made progress was switching from using D18/D19 (Z max/min stops) and also Serial1 to using Serial2 which is pins D16/D17.
I've also disabled EEPROM for now .. one problem at a time.
Perhaps I didn't disable Z stops properly but anyhow .. progress to this ...
I've already switched the Y driver and no change, I'll have to double check the board and wiring. ... Oh yeah, checked the voltages on MS1,MS2 pins and one of them has an indeterminate voltage of .25V or so. That will do it. (should be 0 or 3.2V on a DUE board)
echo:start
echo:[938] HAL_init()
echo:[940] setup_killpin()
echo:[942] tmc_serial_begin()
echo:[945] setup_powerhold()
echo:[947] esp_wifi_init()
PowerUp
Marlin 2.0.7.2
echo: Last Updated: 2020-10-15 | Author: (kpishere, SMARTRAMPS)
echo:Compiled: Jan 27 2021
echo: Free Memory: 84832 PlannerBufferBytes: 1600
echo:[964] buzzer.init()
echo:[966] ui.init()
echo:[1903] ui.show_bootscreen()
echo:[5927] ui.reset_status()
echo:[5929] settings.first_load()
echo: G21 ; Units in mm (mm)
echo: M149 C ; Units in Celsius
echo:; Filament settings: Disabled
echo: M200 S0 D1.75
echo:; Steps per unit:
echo: M92 X80.00 Y80.00 Z800.00 E93.00
echo:; Maximum feedrates (units/s):
echo: M203 X500.00 Y500.00 Z5.00 E25.00
echo:; Maximum Acceleration (units/s2):
echo: M201 X500.00 Y500.00 Z100.00 E5000.00
echo:; Acceleration (units/s2): P R T
echo: M204 P500.00 R500.00 T500.00
echo:; Advanced: B S T J
echo: M205 B20000.00 S0.00 T0.00 J0.08
echo:; Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echo:; Material heatup parameters:
echo: M145 S0 H200 F0
echo: M145 S1 H220 F0
echo:; PID settings:
echo: M301 P28.81 I2.25 D92.34
echo:; LCD Contrast:
echo: M250 C190
echo:; Stepper driver current:
echo: M906 X650 Y650 Z580
echo: M906 T0 E650
echo:; Hybrid Threshold:
echo: M913 X100 Y100 Z3
echo: M913 T0 E30
echo:; StallGuard threshold:
echo: M914 X45 Y70
echo:; Driver stepping mode:
echo: M569 S1 X Y Z
echo: M569 S1 T0 E
echo:; Filament load/unload lengths:
echo: M603 L0.00 U100.00
echo:[6980] thermalManager.init()
echo:[7233] print_job_timer.init()
echo:[7236] endstops.init()
echo:[7239] stepper.init()
echo:[7241] test_tmc_connection(0x1, 0x1, 0x1, 0x1)
Testing X connection... OK
Testing Y connection... Error: All LOW
Testing Z connection... OK
Testing E connection... OK
echo:[7284] setup() completed.
Edited 1 time(s). Last edit at 01/27/2021 07:01AM by NovaHuta.
