Filament Run Out - Marlin Config
Posted by hello_tom
April 11, 2022 02:26AM
Good Morning everybody,
finally I got the time to set up a filament run out sensor, but ...
I used the Z-Max Endstop PINS and changed it in Marlin. When I run a M119 to see the status of the enstop, I find the 3x Min Endstops and the filament. When I m changing manually the status of the filament Input I see the movement with my M119 command.
I enabled the runout sensor and advanced pause mode feature in Marlin as well. .... but when I do a test print and simulate the filament end, nothing happens.
I working with a RAMPS 1.4 and Arduino, Marlin Version 2.0.7.2.
I m lost and don t know what as to do?
Regards
Tom
Re: Filament Run Out - Marlin Config
September 13, 2022 08:15AM
Thank You very much
