Marlin 2.1.2.1 Config: 2 Hotend loops, one Extruder, reasighn E1 to U pins February 03, 2024 12:38AM |
Re: Marlin 2.1.2.1 Config: 2 Hotend loops, one Extruder, reasighn E1 to U pins February 03, 2024 01:37AM |
Admin Registered: 15 years ago Posts: 7,333 |
diff --git a/Marlin/Configuration.h b/Marlin/Configuration.h
index 20802a2839..2004334dab 100644
--- a/Marlin/Configuration.h
+++ b/Marlin/Configuration.h
@@ -88,6 +88,10 @@
// Choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD BOARD_MKS_GEN_L
+ #define I_STOP_PIN 2
+ #define X_STOP_PIN 3
+ #define Y_STOP_PIN 14
+ #define Z_STOP_PIN 18
#endif
@@ -166,14 +170,14 @@
//#define Z2_DRIVER_TYPE A4988
//#define Z3_DRIVER_TYPE A4988
//#define Z4_DRIVER_TYPE A4988
-//#define I_DRIVER_TYPE A4988
+#define I_DRIVER_TYPE DRV8825
//#define J_DRIVER_TYPE A4988
//#define K_DRIVER_TYPE A4988
//#define U_DRIVER_TYPE A4988
//#define V_DRIVER_TYPE A4988
//#define W_DRIVER_TYPE A4988
#define E0_DRIVER_TYPE DRV8825
-#define E1_DRIVER_TYPE DRV8825
+//#define E1_DRIVER_TYPE DRV8825
//#define E2_DRIVER_TYPE A4988
//#define E3_DRIVER_TYPE A4988
//#define E4_DRIVER_TYPE A4988
@@ -199,7 +203,7 @@
* Regardless of these settings the axes are internally named I, J, K, U, V, W.
#ifdef I_DRIVER_TYPE
- #define AXIS4_NAME 'A' // :['A', 'B', 'C', 'U', 'V', 'W']
+ #define AXIS4_NAME 'U' // :['A', 'B', 'C', 'U', 'V', 'W']
#define AXIS4_ROTATES
#endif
#ifdef J_DRIVER_TYPE
@@ -227,7 +231,7 @@
// This defines the number of extruders // extruders ****************************************************
// :[0, 1, 2, 3, 4, 5, 6, 7, 8]
-#define EXTRUDERS 2 //**************************************************
+#define EXTRUDERS 1 //**************************************************
// Generally expected filament diameter (1.75, 2.85, 3.0, ...). Used for Volumetric, Filament Width Sensor, etc.
#define DEFAULT_NOMINAL_FILAMENT_DIA 1.75
@@ -537,7 +541,7 @@
#define TEMP_SENSOR_0 -3
-#define TEMP_SENSOR_1 1
+#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_4 0
@@ -1036,7 +1040,7 @@
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
-//#define USE_IMIN_PLUG
+#define USE_IMIN_PLUG
//#define USE_JMIN_PLUG
//#define USE_KMIN_PLUG
//#define USE_UMIN_PLUG
@@ -1169,14 +1173,14 @@
* Override with M92
* X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]]
-#define DEFAULT_AXIS_STEPS_PER_UNIT { 400, 400, 400, 400 } // { 80, 80, 400, 500 }
+#define DEFAULT_AXIS_STEPS_PER_UNIT { 400, 400, 400, 400, 400 } // { 80, 80, 400, 500 }
* Default Max Feed Rate (linear=mm/s, rotational=°/s)
* Override with M203
-#define DEFAULT_MAX_FEEDRATE { 300, 300, 300, 300 } // { 300, 300, 5, 25 }
+#define DEFAULT_MAX_FEEDRATE { 300, 300, 300, 300, 300 } // { 300, 300, 5, 25 }
//#define LIMITED_MAX_FR_EDITING // Limit edit via M203 or LCD to DEFAULT_MAX_FEEDRATE * 2
#if ENABLED(LIMITED_MAX_FR_EDITING)
@@ -1189,7 +1193,7 @@
* Override with M201
-#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 3000, 3000 } //{ 3000, 3000, 100, 10000 }
+#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 3000, 3000, 3000 } //{ 3000, 3000, 100, 10000 }
//#define LIMITED_MAX_ACCEL_EDITING // Limit edit via M201 or LCD to DEFAULT_MAX_ACCELERATION * 2
#if ENABLED(LIMITED_MAX_ACCEL_EDITING)
@@ -1611,7 +1615,7 @@
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
-//#define I_ENABLE_ON 0
+#define I_ENABLE_ON 0
//#define J_ENABLE_ON 0
//#define K_ENABLE_ON 0
//#define U_ENABLE_ON 0
@@ -1623,7 +1627,7 @@
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
-//#define DISABLE_I false
+#define DISABLE_I false
//#define DISABLE_J false
//#define DISABLE_K false
//#define DISABLE_U false
@@ -1644,7 +1648,7 @@
#define INVERT_X_DIR true //false
#define INVERT_Y_DIR true //false
#define INVERT_Z_DIR false
-//#define INVERT_I_DIR false
+#define INVERT_I_DIR false
//#define INVERT_J_DIR false
//#define INVERT_K_DIR false
//#define INVERT_U_DIR false
@@ -1685,7 +1689,7 @@
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
-//#define I_HOME_DIR -1
+#define I_HOME_DIR -1
//#define J_HOME_DIR -1
//#define K_HOME_DIR -1
//#define U_HOME_DIR -1
@@ -1705,8 +1709,8 @@
#define X_MAX_POS X_BED_SIZE
#define Y_MAX_POS Y_BED_SIZE
#define Z_MAX_POS 1000 // 200
-//#define I_MIN_POS 0
-//#define I_MAX_POS 50
+#define I_MIN_POS 0
+#define I_MAX_POS 50
//#define J_MIN_POS 0
//#define J_MAX_POS 50
//#define K_MIN_POS 0
@@ -2099,7 +2103,7 @@
#endif
// Homing speeds (linear=mm/min, rotational=°/min)
-#define HOMING_FEEDRATE_MM_M { (50*60), (50*60), (50*60) }
+#define HOMING_FEEDRATE_MM_M { (50*60), (50*60), (50*60), (50*60) }
// Validate that endstops are triggered on homing moves
#define VALIDATE_HOMING_ENDSTOPS
diff --git a/Marlin/Configuration_adv.h b/Marlin/Configuration_adv.h
index b3ba8f4919..fae97494b5 100644
--- a/Marlin/Configuration_adv.h
+++ b/Marlin/Configuration_adv.h
@@ -877,8 +877,8 @@
//#define SENSORLESS_BACKOFF_MM { 2, 2, 0 } // (linear=mm, rotational=°) Backoff from endstops before sensorless homing
-#define HOMING_BUMP_MM { 5, 5, 2 } // (linear=mm, rotational=°) Backoff from endstops after first bump
-#define HOMING_BUMP_DIVISOR { 2, 2, 4 } // Re-Bump Speed Divisor (Divides the Homing Feedrate)
+#define HOMING_BUMP_MM { 5, 5, 2, 2 } // (linear=mm, rotational=°) Backoff from endstops after first bump
+#define HOMING_BUMP_DIVISOR { 2, 2, 4, 4 } // Re-Bump Speed Divisor (Divides the Homing Feedrate)
//#define HOMING_BACKOFF_POST_MM { 2, 2, 2 } // (linear=mm, rotational=°) Backoff from endstops after homing
//#define XY_COUNTERPART_BACKOFF_MM 0 // (mm) Backoff X after homing Y, and vice-versa
@@ -1095,7 +1095,7 @@
//#define SHAPING_MENU // Add a menu to the LCD to set shaping parameters.
#endif
-#define AXIS_RELATIVE_MODES { false, false, false, false }
+#define AXIS_RELATIVE_MODES { false, false, false, false, false }
// Add a Duplicate option for well-separated conjoined nozzles
//#define MULTI_NOZZLE_DUPLICATION
@@ -1345,7 +1345,7 @@
// @section lcd
#if HAS_MANUAL_MOVE_MENU
- #define MANUAL_FEEDRATE { 50*60, 50*60, 4*60, 2*60 } // (mm/min) Feedrates for manual moves along X, Y, Z, E from panel
+ #define MANUAL_FEEDRATE { 50*60, 50*60, 4*60, 2*60, 2*60 } // (mm/min) Feedrates for manual moves along X, Y, Z, E from panel
#define FINE_MANUAL_MOVE 0.025 // (mm) Smallest manual move (< 0.1mm) applying to Z on most machines
#if IS_ULTIPANEL
#define MANUAL_E_MOVES_RELATIVE // Display extruder move distance rather than "position"
Re: Marlin 2.1.2.1 Config: 2 Hotend loops, one Extruder, reasighn E1 to U pins February 03, 2024 06:16PM |
