Vertical X-axis standard !And Contest W/ Prize Updates August 28, 2011 09:53PM |
Re: Vertical X-axis standard August 28, 2011 11:38PM |
Re: Vertical X-axis standard August 29, 2011 12:19AM |
Re: Vertical X-axis standard August 29, 2011 12:40AM |
Re: Vertical X-axis standard August 29, 2011 05:11AM |
Re: Vertical X-axis standard August 29, 2011 05:30AM |
Re: Vertical X-axis standard August 29, 2011 10:53AM |
Re: Vertical X-axis standard August 30, 2011 10:21AM |
Re: Vertical X-axis standard August 30, 2011 11:27PM |
Re: Vertical X-axis standard August 31, 2011 03:30AM |
Re: Vertical X-axis standard August 31, 2011 04:33AM |
Re: Vertical X-axis standard August 31, 2011 08:01AM |
bryanandaimee
the current prusa Z/X axis assembly is already about 60 mm tall so very little loss of Z travel if we keep it about that tall
Re: Vertical X-axis standard August 31, 2011 12:24PM |
Re: Vertical X-axis standard August 31, 2011 12:50PM |
Re: Vertical X-axis standard August 31, 2011 02:58PM |
Re: Vertical X-axis standard September 01, 2011 10:19AM |
Re: Vertical X-axis standard September 01, 2011 11:14AM |
// PRUSA Mendel // GNU GPL v2 // Z threaded rod constraint include outer_diameter = m8_diameter/2+3.3; shaft_separation = 30; bearing_od = 22.6; bearing_id = m8_diameter; bearing_rodhole_d = bearing_id + 3;
Re: Vertical X-axis standard September 01, 2011 05:57PM |
, I'll declare the sense of the discussion to be that a good standard would be 70 mm x smooth rod center to center and 30 mm z smooth to threaded rod center to center. This should ensure that any vertical x axis assembly/x carriage design will play at least sorta nice with other conforming bots. Hows about we take that as a preliminary standard, allow a week for further comment, and try to call it final if there's no change in the consensus of the discussion by then.
Re: Vertical X-axis standard September 01, 2011 06:01PM |
Re: Vertical X-axis standard September 01, 2011 06:11PM |
Re: Vertical X-axis standard September 01, 2011 07:54PM |
See post here [forums.reprap.org]. I'll give it some thought. As for the proper page for it, I think there is a reprap wiki page on standards. I don't know if there are any actual proposed standards in it yet or not. As for promotion, if I decide to do a contest, you'll see promotion, I can guarantee you that.
Re: Vertical X-axis standard September 03, 2011 05:47AM |
Re: Vertical X-axis standard September 03, 2011 06:28AM |
Re: Vertical X-axis standard September 03, 2011 04:03PM |
Re: Vertical X-axis standard September 07, 2011 01:10PM |
Re: Vertical X-axis standard September 09, 2011 03:22AM |
Re: Vertical X-axis standard September 10, 2011 09:40PM |
Re: Vertical X-axis standard September 12, 2011 12:05PM |
Re: Vertical X-axis standard September 12, 2011 12:33PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Vertical X-axis standard September 12, 2011 12:40PM |
