Re: Vertical X-axis standard September 12, 2011 01:19PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Vertical X-axis standard September 12, 2011 02:15PM |
Re: Vertical X-axis standard September 12, 2011 03:46PM |
Re: Vertical X-axis standard September 12, 2011 09:28PM |
Re: Vertical X-axis standard !And Contest! September 13, 2011 06:27AM |
Yes if they flex they will balance the load but the whole point is that we don't want them to flex.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Vertical X-axis standard !And Contest! September 13, 2011 08:20AM |
Another thing is, the weight of the extruder is constant, so it always makes the mechanics flex exactly the same amount.
Flexing not only varies by force, but even more by distance. Accordingly, the bigger the plastic parts are, the more they flex. So, smaller parts do not only print faster, they also flex less - as a rule of thumb.
BTW., I hope you don't recognize this long list as a blow in your face, I just tried to outline a few basic rules.
Re: Vertical X-axis standard !And Contest! September 13, 2011 11:22PM |
Re: Vertical X-axis standard !And Contest! September 14, 2011 06:17PM |
Re: Vertical X-axis standard !And Contest! September 14, 2011 06:32PM |
Re: Vertical X-axis standard !And Contest! September 14, 2011 08:21PM |
Re: Vertical X-axis standard !And Contest! September 14, 2011 09:07PM |
Re: Vertical X-axis standard September 16, 2011 02:52PM |
Re: Vertical X-axis standard September 16, 2011 03:46PM |
Re: Vertical X-axis standard !And Contest! September 21, 2011 05:05PM |
Re: Vertical X-axis standard !And Contest! September 21, 2011 05:08PM |
Re: Vertical X-axis standard !And Contest! September 22, 2011 12:40PM |
Re: Vertical X-axis standard !And Contest! September 22, 2011 03:28PM |
Re: Vertical X-axis standard !And Contest! September 22, 2011 04:46PM |
Re: Vertical X-axis standard !And Contest! September 28, 2011 03:48PM |
Re: Vertical X-axis standard !And Contest! September 30, 2011 01:54PM |
Re: Vertical X-axis standard !And Contest! October 02, 2011 06:13PM |
Re: Vertical X-axis standard !And Contest! October 04, 2011 11:18AM |
Re: Vertical X-axis standard !And Contest! October 04, 2011 05:20PM |
Re: Vertical X-axis standard !And Contest! October 04, 2011 10:11PM |
Re: Vertical X-axis standard !And Contest! October 04, 2011 11:10PM |
Re: Vertical X-axis standard !And Contest! October 05, 2011 09:19AM |
Re: Vertical X-axis standard !And Contest! October 05, 2011 10:52AM |
Re: Vertical X-axis standard !And Contest! October 05, 2011 11:02AM |
Re: Vertical X-axis standard !And Contest! October 05, 2011 12:30PM |
Re: Vertical X-axis standard !And Contest! October 05, 2011 06:22PM |
