Vertical X-axis standard !And Contest W/ Prize Updates August 28, 2011 09:53PM |
Re: Vertical X-axis standard August 28, 2011 11:38PM |
Re: Vertical X-axis standard August 29, 2011 12:19AM |
Re: Vertical X-axis standard August 29, 2011 12:40AM |
Re: Vertical X-axis standard August 29, 2011 05:11AM |
Re: Vertical X-axis standard August 29, 2011 05:30AM |
Re: Vertical X-axis standard August 29, 2011 10:53AM |
Re: Vertical X-axis standard August 30, 2011 10:21AM |
Re: Vertical X-axis standard August 30, 2011 11:27PM |
Re: Vertical X-axis standard August 31, 2011 03:30AM |
Re: Vertical X-axis standard August 31, 2011 04:33AM |
Re: Vertical X-axis standard August 31, 2011 08:01AM |
bryanandaimee
the current prusa Z/X axis assembly is already about 60 mm tall so very little loss of Z travel if we keep it about that tall
Re: Vertical X-axis standard August 31, 2011 12:24PM |
Re: Vertical X-axis standard August 31, 2011 12:50PM |
Re: Vertical X-axis standard August 31, 2011 02:58PM |
Re: Vertical X-axis standard September 01, 2011 10:19AM |
Re: Vertical X-axis standard September 01, 2011 11:14AM |
// PRUSA Mendel // GNU GPL v2 // Z threaded rod constraint include outer_diameter = m8_diameter/2+3.3; shaft_separation = 30; bearing_od = 22.6; bearing_id = m8_diameter; bearing_rodhole_d = bearing_id + 3;
Re: Vertical X-axis standard September 01, 2011 05:57PM |
Re: Vertical X-axis standard September 01, 2011 06:01PM |
Re: Vertical X-axis standard September 01, 2011 06:11PM |
Re: Vertical X-axis standard September 01, 2011 07:54PM |
Re: Vertical X-axis standard September 03, 2011 05:47AM |
Re: Vertical X-axis standard September 03, 2011 06:28AM |
Re: Vertical X-axis standard September 03, 2011 04:03PM |
Re: Vertical X-axis standard September 07, 2011 01:10PM |
Re: Vertical X-axis standard September 09, 2011 03:22AM |
Re: Vertical X-axis standard September 10, 2011 09:40PM |
Re: Vertical X-axis standard September 12, 2011 12:05PM |
Re: Vertical X-axis standard September 12, 2011 12:33PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Vertical X-axis standard September 12, 2011 12:40PM |
