Vertical X-axis PCB Mill carriage September 14, 2011 07:17AM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 10:05AM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 11:11AM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 02:12PM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 04:35PM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 03:01AM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 04:43AM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 05:40AM |
evidence from CNC machines shows that MDF and other wood-based machines expand and contract to a measurable degree depending on humidity.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 08:11AM |
Admin Registered: 19 years ago Posts: 7,883 |
A Mendel with only printed and wooden parts, anyone?
Re: Vertical X-axis PCB Mill carriage September 15, 2011 09:43AM |
nophead
Yes that is what I am working on ATM, see [forums.reprap.org]. All the studding frame is replaced by a few sheets of 12mm MDF, much stiffer in the directions it needs to be. I doubt it would be much good for milling due to the use of belts, but it would be a lot better than a normal Mendel.
Re: Vertical X-axis PCB Mill carriage September 15, 2011 12:35PM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 01:26PM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 07:59PM |
), I'm at least prepared to try milling on a Prusa frame. If it can be demonstrated to be workable, what's the problem? At the moment it's just people saying "it can't be done"! Okay, based on previous experience of standard frames using Dremel extensions (poor/loose spindles and slow mill rotation speed seem to be two of the main problems reported), but I'm proposing changes to address many of the issues. Feed speed will not be high, and drill tip resistance should not be great either.|
Re: Vertical X-axis PCB Mill carriage September 16, 2011 07:26AM |
Me for one, i would also like to yell more on the topic, except you know, nobody would pay attention to me ever, so ... i will have to save my breath
Re: Vertical X-axis PCB Mill carriage September 16, 2011 10:08AM |
