Techzone Huxley unusable... is a fraud??? April 04, 2012 08:16AM |
Re: Techzone Huxley unusable... is a fraud??? April 04, 2012 09:40AM |
Admin Registered: 14 years ago Posts: 2,569 |
Re: Techzone Huxley unusable... is a fraud??? April 04, 2012 11:22AM |
Re: Techzone Huxley unusable... is a fraud??? April 04, 2012 03:57PM |
//********************************************************************************************** // These settings are mainly for a Mendel with an Arduino Mega controller and Pololu stepper drivers // See [reprap.org] #if MOTHERBOARD == 3 //#define MENDEL 1 // Comment out this if you are using a thermocouple //#define USE_THERMISTOR //#define USE_DS2760 #define USE_TECHZONETIPMANAGE #ifdef USE_DS2760 #define OW 13 #define OWTroubleshoot 13 #define ReadNet 0x33 #define SkipNet 0xCC #define RdReg 0x69 #define thermoTypeK //#define thermoTypeJ //#define thermoTypeT #endif // Set to 1 if enable pins are inverting // For RepRap stepper boards version 1.x the enable pins are *not* inverting. // For RepRap stepper boards version 2.x and above the enable pins are inverting. #define INVERT_ENABLE_PINS 1 // Set to one if the axis opto-sensor outputs inverting (ie: 1 means open, 0 means closed) // RepRap opto endstops with H21LOI sensors are not inverting; ones with H21LOB // are inverting. #define X_ENDSTOP_INVERTING true #define Y_ENDSTOP_INVERTING true #define Z_ENDSTOP_INVERTING true // Motherboard 3 driving Pololu microstepping controllers - 16 microsteps // Axis scaling in stepper-motor steps per mm of movement //#define X_STEPS_PER_MM 8.038 //10 tooth #define X_STEPS_PER_MM 10.047 #define X_STEPS_PER_INCH (X_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_X_DIR 0 #define Y_STEPS_PER_MM 10.047 #define Y_STEPS_PER_INCH (Y_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Y_DIR 0 //#define Z_STEPS_PER_MM 805.030 // had to be multiplied by 1.242189732 #define Z_STEPS_PER_MM 1000 #define Z_STEPS_PER_INCH (Z_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Z_DIR 0 // Stepper-driven extruder // E_STEPS_PER_MM is the number of steps needed to // extrude 1mm out of the nozzle. E0 for extruder 0; // E1 for extruder 1, and so on. //#define E_STEPS_PER_MM 0.9 // NEMA 17 extruder 5mm diameter drive - empirically adjusted //#define E0_STEPS_PER_MM 3.5 // original stock techzone value !!! #define E0_STEPS_PER_MM 160.727 #define E1_STEPS_PER_MM 17.6 // NEMA 17 59/11 geared extruder 8mm diameter drive // The temperature routines get called each time the main loop // has gone round this many times #define SLOW_CLOCK 2000 #endif //********************************************************************************************** // The speed at which to talk with the host computer; default is 19200 //#define HOST_BAUD 19200 // *RO #define HOST_BAUD 115200 // Set 1s where you have endstops; 0s where you don't // Both Darwin and Mendel have MIN endstops, but not MAX ones. #define ENDSTOPS_MIN_ENABLED 1 #define ENDSTOPS_MAX_ENABLED 0 // The number of mm below which distances are insignificant (one tenth the // resolution of the machine is the default value). #define SMALL_DISTANCE 0.01 // *RO // Useful to have its square #define SMALL_DISTANCE2 (SMALL_DISTANCE*SMALL_DISTANCE) // *RO //our maximum feedrates in mm/minute #define FAST_XY_FEEDRATE 4800.0 #define FAST_Z_FEEDRATE 120.0 // Data for acceleration calculations // Comment out the next line to turn accelerations off #define ACCELERATION_ON #define SLOW_XY_FEEDRATE 1200.0 // Speed from which to start accelerating #define SLOW_Z_FEEDRATE 10.0 #if INVERT_ENABLE_PINS == 1 // *RO #define ENABLE_ON LOW // *RO #else // *RO #define ENABLE_ON HIGH // *RO #endif // *RO // Set these to 1 to disable an axis when it's not being used, // and for the extruder. Usually only Z is disabled when not in // use. You will probably find that disabling the others (i.e. // powering down the steppers that drive them) when the ends of // movements are reached causes poor-quality builds. (Inertia // causes overshoot if the motors are not left powered up.) #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 0 #define DISABLE_E 0 // The number of 5-second intervals to wait at the target temperature for things to stabilise. // Too short, and the extruder will jam as only part of it will be hot enough. // Too long and the melt will extend too far up the insulating tube. // Default value: 10 #define WAIT_AT_TEMPERATURE 10 // PID gains. E_ = extruder, B_ = bed. The Es are about right for a brass extruder about 8 mm // in diameter and 30 mm long heated by a 6 ohm coil with a 12v supply. The B_ values are OK // for the bed described here: [reprap.org] // Extruding increase biases the input to the extruder heater when the extruder // is running as it requires more power. #define E_TEMP_PID_PGAIN 2 #define E_TEMP_PID_IGAIN 0.15 #define E_TEMP_PID_DGAIN 0.5 #define EXTRUDING_INCREASE 7 #define B_TEMP_PID_PGAIN 2 #define B_TEMP_PID_IGAIN 0.07 #define B_TEMP_PID_DGAIN 1 //our command string length #define COMMAND_SIZE 128 // *RO // Our response string length #define RESPONSE_SIZE 256 // *RO // The size of the movement buffer #define BUFFER_SIZE 4 // *RO // Number of microseconds between timer interrupts when no movement // is happening #define DEFAULT_TICK (long)1000 // *RO // What delay() value to use when waiting for things to free up in milliseconds #define WAITING_DELAY 1 // *RO
if zString is not None and zString != self.lastZString:
self.output.write('G1 F80.0\n')
self.output.write('G1 Z' + zString + ' F100.0\n')
self.output.write('G1 F' + feedRateString + '\n')
Re: Techzone Huxley unusable... is a fraud??? April 07, 2012 08:26AM |
Re: Techzone Huxley unusable... is a fraud??? April 07, 2012 09:29AM |
Re: Techzone Huxley unusable... is a fraud??? April 07, 2012 10:06AM |
Re: Techzone Huxley unusable... is a fraud??? April 15, 2012 03:01PM |
Re: Techzone Huxley unusable... is a fraud??? August 30, 2012 08:20AM |
Re: Techzone Huxley unusable... is a fraud??? August 30, 2012 10:09AM |
Re: Techzone Huxley unusable... is a fraud??? October 20, 2012 06:02AM |
Re: Techzone Huxley unusable... is a fraud??? October 20, 2012 06:47AM |
Re: Techzone Huxley unusable... is a fraud??? October 21, 2012 12:22AM |
Re: Techzone Huxley unusable... is a fraud??? October 21, 2012 03:55AM |
Re: Techzone Huxley unusable... is a fraud??? October 21, 2012 02:22PM |
Re: Techzone Huxley unusable... is a fraud??? October 21, 2012 02:51PM |
Re: Techzone Huxley unusable... is a fraud??? October 21, 2012 04:12PM |
Re: Techzone Huxley unusable... is a fraud??? October 22, 2012 12:34AM |
Re: Techzone Huxley unusable... is a fraud??? October 22, 2012 04:25AM |
Re: Techzone Huxley unusable... is a fraud??? October 22, 2012 08:05PM |
Re: Techzone Huxley unusable... is a fraud??? October 23, 2012 11:29PM |
Re: Techzone Huxley unusable... is a fraud??? October 24, 2012 02:08AM |
Re: Techzone Huxley unusable... is a fraud??? October 25, 2012 02:39AM |
Re: Techzone Huxley unusable... is a fraud??? October 25, 2012 03:36AM |
Re: Techzone Huxley unusable... is a fraud??? October 25, 2012 04:42AM |
Re: Techzone Huxley unusable... is a fraud??? October 25, 2012 05:34AM |
Re: Techzone Huxley unusable... is a fraud??? October 25, 2012 01:01PM |
Re: Techzone Huxley unusable... is a fraud??? October 25, 2012 02:15PM |
Re: Techzone Huxley unusable... is a fraud??? October 25, 2012 08:40PM |
Re: Techzone Huxley unusable... is a fraud??? October 26, 2012 02:43AM |
