Dear Guys,-
When I press the home button for the X-axis, the X-axis is only moving a little bit to minus X and not to Home. To get the X home I need manually to move it to the endstop, when it’s at the end and I press Home it knows X is Home.
Do anyone know, how to fix the problem?, in order not to manually move the X-axis Home, and just press Home.
The Y and Z axes Home buttons works.
/Nimal
Re: Problem moving X- axis home using the Home button in the Printer Interface (skeinforge)
May 17, 2012 05:20PM
Have you run the endstop wires near to the motor wires? If so you can get false triggering.
I moved the wires and it works. THANKS!
